Clutch Release - Page 5 - MVAgusta.net
 18Likes
post #41 of 72 (permalink) Old 06-17-2019, 10:43 AM
Originally Posted by NippyNelmo View Post
I'm due to go away on holiday with the MV in a few days but will definitely give it a go on my return. Absolutely nothing to lose and potentially many ££'s to gain as I can only imagine how much a new basket would cost. On tickover and at low revs, the engine (clutch?) sounds like a bag of spanners so it will be interesting to see if the filing will make the rattle worse!
I'm in a similar position. Got my bike booked in for the annual service and a check on the clutch mechanism, the day before the big Euro trip in a few weeks' time. I mentioned the technical bulletin when booking the service, though they didn't immediately know of it. Mine also sounds like a bag of spanners, but I believe the Euro4 models are significantly quieter.
I've had some terrifying moments on the TVL on every extended trip, with the bike kangarooing forward - it's a wonder I haven't crashed yet! It's make or break time. It often happens in traffic or town riding. If it can't be fixed then I'll trade it in. I've got a demo of the SCS version when mine's in the workshop, which might be an answer (at a price!) otherwise I'll begin the quest again for a fun touring bike...
MV Turismo Veloce Lusso
Cripes is offline
post #42 of 72 (permalink) Old 06-17-2019, 07:18 PM
Mario Landavoz's Avatar
I've had this same problem with multiple bikes over the years. It has always been glazed plates caused by the oil I have used.
Change the oil to the recommended type. You can de-glaze the plates with sandpaper over a flat plate. I use a Blanchard ground 1/2' plate. The other option is to just replace the plates. Most motorcycle clutches are fairly simple to work on.
NippyNelmo likes this.
2017 Dragster
2014 BMW R1200GS
Mario Landavoz is offline
post #43 of 72 (permalink) Old 06-18-2019, 12:54 AM
Yes, I have heard this explanation, but what specific oil are you using? Mine is serviced by an official dealership so presumably everything is to factory spec, which is strange if you're saying it's the oil they use.
Cripes is offline
post #44 of 72 (permalink) Old 06-18-2019, 10:31 AM
Teeps's Avatar
Do any of you use the "Quick Shift" feature?
If so how often?
Also do you use it for up and down shifting?
add:
Odometer reading?
2016 Turismo Veloce 800
Teeps is offline
post #45 of 72 (permalink) Old 06-18-2019, 10:40 AM
If so how often?
On the right roads, certainly, and when in the mood for play! Mostly upshifts and only the occasional downshift.
Cripes is offline
post #46 of 72 (permalink) Old 06-18-2019, 10:43 AM
Fastspy's Avatar
If so how often?
I've yet to experience the problem noted with inconsistent clutch engagement.
I do use the "quick shift" feature all the time both up and down shifting. Down shifting only off throttle and up shift while on throttle. IMO, the quick shifting is a huge upside for fun when riding this moto.
I use Castrol 4T 5w-40 full synthetic oil.
edit 13K miles on my moto
Fastspy is online now
post #47 of 72 (permalink) Old 06-18-2019, 01:11 PM
Teeps's Avatar
I just added odometer reading to my post above.
I have 4200 miles on my '16 TV and also have not experienced the symptom either.
Not really a fan of the Q/S.
I've used it some, but now have it turned off.
The Castrol you are using is a good deal... even has the correct specs for MV on the package, too. (I might have to switch)
Teeps is offline
post #48 of 72 (permalink) Old 06-18-2019, 08:24 PM
Fastspy's Avatar
A bit over 13K miles on mine. After the initial oil change at 632 miles, I've changed the oil more frequent than the service interval listed in the shop manual/owners manual. Usually change at about 3K interval.
Teeps likes this.
post #49 of 72 (permalink) Old 06-19-2019, 12:29 AM
MarcSilverTriple's Avatar
on dirt bikes when the basket fingers become notchy you can file them smooth and re-use the basket without issue. All depends on how bad the basket fingers are but might be worth a try before buying a new basket.
Clutch basket within the pictures is the one before the recall, and not the new one. Suggest a check with a dealer if it is yours.
Marc,
Turismo Veloce in France
Ride with us in Vosges :
MarcSilverTriple is offline
post #50 of 72 (permalink) Old 06-19-2019, 09:43 AM
Fastspy's Avatar
No it is not mine. I used a photo off this forum as a reference for the clutch basket finger abrasions.
Sorry if it confused those following along in this thread.
