Oil leak at elec pole clutch switch - MVAgusta.net
  • 1 Post By Arcimboldo
post #1 of 4 (permalink) Old 01-13-2019, 11:57 PM Thread Starter
mva2017's Avatar
Unhappy Oil leak at elec pole clutch switch
Hi there,
I have a oil leak at the electronic pole clutch switch, I tempted to use steel glue, but can not stop oil leak. Anyone know how to fix it? Please. Thank you so much.
I have Agriculture Bike and It is Turismo Veloce
mva2017 is offline
post #2 of 4 (permalink) Old 01-14-2019, 02:08 AM
MarcSilverTriple's Avatar
Originally Posted by mva2017 View Post
Hi there,
I suggest you change the clutch switch, its complete failure is getting close. It generally starts by leaking, and later on doesn't work anymore at all.
Marc,
Turismo Veloce in France
MarcSilverTriple is offline
post #3 of 4 (permalink) Old 01-14-2019, 05:24 AM
Arcimboldo's Avatar
Cool
Well played Sir!
'Xcept when it starts leaking it's too late.
The clutch fluid will rapidly drain then no more fluid and no more clutch!
Order a new switch.
'Case cluth switch not in stock at a dealer some waiting might occur.
Plug the dead clutch switch with anything handy.
JB weld and others won't hold the pressure for long.
Stuffing a short length cut from a 3.5mm thick O-ring in the clutch switch hole stops the leak.
Screw the old dead switch back in the clutch receiver.
Forget the wires..
Refill the bowl to replace leaked fluid.
If the clutch lever spongy bleed the clutch line.
And go on your merry way until the new part arrives.
Fastspy likes this.
Dragster
Arcimboldo is offline
post #4 of 4 (permalink) Old 01-14-2019, 11:20 AM
Teeps's Avatar
Check this thread: https://www.mvagusta.net/forum/74-tu...d-1-8-bsp.html
You can probably find what you need Locally...
2016 Turismo Veloce 800
Teeps is offline
