50,000 km's TV - MVAgusta.net
 5Likes
  • 2 Post By doggy
  • 3 Post By Black_Gold_Saw
  • 1 Post By Aus Mv
  • 2 Post By revhead1957
post #1 of 7 (permalink) Old 03-02-2018, 04:01 PM Thread Starter
doggy's Avatar
50,000 km's TV
Worth a watch .
gotfolk and gotfolk like this.
Brutale 800 Italia
Monster 796 .
doggy is offline
post #2 of 7 (permalink) Old 03-02-2018, 05:19 PM
Black_Gold_Saw's Avatar
So they tested a first year Turismo Veloce and basically its a well build good machine. That definitly holds up in all weather conditions.
First year valve problems have been sorted out to later modelyear bikes so thats fixed.
As for the electronics I have to disagree. If you're rough with the key and snap it off on your own you cant blame MV for having the security feature in it. (2nd key... what happened to that? Did it not work or never recieved a second key?)
zzaraxx, zzaraxx and Duc-Mike like this.
"Mileena"
Black_Gold_Saw is offline
post #3 of 7 (permalink) Old 03-02-2018, 07:15 PM
Aus Mv's Avatar
I broke my key and got a new one from a locksmith, I now use it as a spare.
Duc-Mike likes this.
Aus Mv is offline
post #4 of 7 (permalink) Old 03-05-2018, 03:44 AM
mva2017's Avatar
How do Locksmith unlock and transfer the smart key for your spare key? please explain.
I have Agriculture Bike and It is Turismo Veloce
mva2017 is offline
post #5 of 7 (permalink) Old 03-05-2018, 05:29 AM
revhead1957's Avatar
Some locksmiths have a computer program that is able to copy the necessary codes on to a new key.
The video is very complimentary. I find it amazing that the sprag issue, which seems to be a common issue on this forum, is not evident with this test.
mva2017 and mva2017 like this.
revhead1957 is offline
The Following User Says Thank You to revhead1957 For This Useful Post:
post #6 of 7 (permalink) Old 03-05-2018, 12:41 PM
MarcSilverTriple's Avatar
It may not be that surprising: I asked my dealer about sprag risks. What he told me is that there was very few issues among the very first delivered bikes (TV/TVL), and no for bikes delivered later. And he mentioned quite a few of them have already heavy mileage (multiple in the 30K km already). Apparently the very first sprag were not the same than the later ones, and as well there was a modification of the ECU programmation. He also mentioning the starting behavior is slightly different. A solved issue maybe?
That being said, was there anyone with this same issue on Euro 4 bikes?
Perhaps there is updates of the ECU software to be applied on other Euro 3 models as well.
By the way, when you looked at what happened in the past for other manufacturers with 3 cylinders, Sprag issues were quite a known issue on Triumph models till end of 1999. There was first a modification of the position of the sprag to make it easier to access and to change, and then later on other modifications and revamped injection software. It took them about 8+ years to give a proper solution to the problem. Not sure if Yamaha got this type of problems with their 3 cylinders...
Marc,
Turismo Veloce in France
MarcSilverTriple is offline
post #7 of 7 (permalink) Old 03-05-2018, 03:16 PM
Teeps's Avatar
see this thread: http://www.mvagusta.net/forum/74-tur...30-tv-key.html post #8
2016 Turismo Veloce 800
Teeps is offline
