Loose weight more than 10kg for TV in year 2018 - MVAgusta.net
 22Likes
post #1 of 25 (permalink) Old 01-19-2018, 03:58 AM Thread Starter
mva2017's Avatar
Hi all,
I am listen to doctor and his advises, I can loose weight for my TV more than 10kg as below
1. Replace OEM Exhaust with Akrapovic R1, straight pipe. loose around 5kg.
2. Replace OEM Battery with Lithium Battery, loose another 2-3kg.
3. Replace OEM signal, number plates... with number Plate hide under back seat and use two button signal, this loose another 3kg.
4. Take off the center stand, loose 2-3kg
All change above cost around USD 1000. Please advises anything else in TV that I should replace to reduce the weight of my TV.
Thanks all.
I have Agriculture Bike and It is Turismo Veloce
mva2017 is offline
post #2 of 25 (permalink) Old 01-19-2018, 05:23 AM
change wheels to forget Aluminum another 1.5kg I guess (~1800 $), more weight saving if you go for magnesium or carbon but also way more expensive
light rear brake disc (0,4 kg 75$ + postage)
all the other parts will get more expensive: titanium/magnesium/aluminum instead of stock parts
mva2017 and mva2017 like this.
Nephalem is offline
The Following User Says Thank You to Nephalem For This Useful Post:
post #3 of 25 (permalink) Old 01-19-2018, 07:46 AM
Lighter wheels will also improve handling significantly..... Good investment.
mva2017, mva2017 and Duc-Mike like this.
post #4 of 25 (permalink) Old 01-19-2018, 01:42 PM
MarcSilverTriple's Avatar
We are speaking about a Turismo Veloce here, not a F3... Large handlebar makes things easier. Additionally, I do think the geometry is made to make the bike easier to handle than it is for a F3 or even a Brutale...
And yes, Lithium battery and aftermarket exhaust is likely to reduce the weight about a lot already (and probably much more than I can consider loose myself with a regime :-D)
Gero HH, Gero HH, mva2017 and 4 others like this.
Marc,
Turismo Veloce in France
MarcSilverTriple is offline
The Following 2 Users Say Thank You to MarcSilverTriple For This Useful Post:
post #5 of 25 (permalink) Old 01-20-2018, 04:09 AM Thread Starter
mva2017's Avatar
Thanks to all,
I might change the font disc and rear disk to lighter one and also change the clutch cover to CNC clear cover and CNC slipper clutch set or EVR clutch set, but wonder which one is better for Turimo, to my view CNC sliper clutch set look more sexy.
All other parts like titanium, carbon or magnesium, could be replace one by one later on.
have a great weekend to you.
mva2017 is offline
post #6 of 25 (permalink) Old 01-20-2018, 09:08 AM
Just remember that Titanium is heavier than aluminum.
post #7 of 25 (permalink) Old 01-20-2018, 01:13 PM
Gero HH's Avatar
do I miss something here??
We talking about a touring bike and not about a race bike where every pound is counting...
to change the OEM battery to a lithium battery and get another exhaust is ok and has other reasons instead of losing weight .. well at least in my opinion....
Well maybe I will lose some weight too, what about 15kg and then I will drive without clothing and helmet that will bring another 6kg
and maybe then I will be 5km/h faster as before
dougn, dougn, Marko G. and 14 others like this.
Gero
______________________
2016 Turismo Veloce 800 Lusso
Gero HH is offline
post #8 of 25 (permalink) Old 01-22-2018, 07:59 AM
Terrys409's Avatar
I replaced my worn Scorpion front tire with an EVO T30, which I like very much, and noticed how heavy the front wheel is. I do not need to shed any pounds for any reason, but again, that is a heavy wheel.
Duc-Mike likes this.
Terrys409 is offline
post #9 of 25 (permalink) Old 01-22-2018, 10:55 AM
number2's Avatar
If the weight is loose then tie it down or you lose it.
number2 is offline
post #10 of 25 (permalink) Old 01-22-2018, 10:56 AM
The stock wheels are heavy indeed.
jdgun is offline
