standard sport map set - MVAgusta.net
post #1 of 7 (permalink) Old 12-10-2015, 04:08 AM Thread Starter
lelemvtv802's Avatar
Hi,
for all that ask "how is set the standard sport map on mvtv base ?" this is what MV Agusta answer me.
Emanuele
Gentile Sig. Emanuele,
di seguito potrà trovare i parametri della mappa Sport:
gas sensivity HIGH
max engine torque Full Power
engine brake Low
engine response Fast
rpm limiter hard
Cordiali saluti,
Customer Care MV Agusta/Cagiva
MV AGUSTA Motor S.p.A. Via G. Macchi, 144 - 21100 Varese
Office Phone +39.0332.254.421 Numero Verde Italia 800364406 Fax +39.0332.329.379
www.mvagusta.com
lelemvtv802 is offline
post #2 of 7 (permalink) Old 12-10-2015, 10:18 AM
EvilSteve's Avatar
Interesting that they'd do the hard rev limiter.
I've been wanting MV to allow us to edit the default options since I don't really like the high sensitivity setting.
2017 KTM 1290 Super Duke GT
EvilSteve is offline
post #3 of 7 (permalink) Old 12-13-2015, 01:36 PM
Can't you make the custom map be the sport map except with the medium sensitivity for gas?
Lion is offline
post #4 of 7 (permalink) Old 12-13-2015, 02:49 PM
jimboF4's Avatar
You are right Lion yes you can choose settings in custom map, gas sensitivity being one, I think Steve was indicating he would like more free play within the pre set limits offered.
Having now ridden the bike a good bit I cannot fault the pre set modes MV have chosen, the touring mode works just great for commuting and general riding, the sport mode works well when you want to shift along a bit. If I need more than thee offerings I have chosen the wrong bike to ride and need one of our Brutales or the F4 1000R !
jimboF4
jimboF4 is offline
post #5 of 7 (permalink) Old 12-13-2015, 10:08 PM
EvilSteve's Avatar
I want to use my custom map for other stuff, not to "fix" the sport mode's overly sensitive throttle.
For me, the "high" setting on gas sensitivity isn't something I like to use but, otherwise I'd be fine with the sport setting even with the hard rev limiter.
What I want to know is which suspension setting is used for the sport mode when you switch to it. The suspension can be changed separately but, when it's set for the custom map, it stays with the map until you select something else so, where does the sport mode's setting come from?
post #6 of 7 (permalink) Old 12-16-2015, 09:59 AM
1. I thought the TV engine maps and suspension maps were independent of each other (as opposed to the Multistrada's package - motor and suspension for each of the four riding mode).
2. Can you set and save various engine and suspension maps on the app and then apply them when you want/need them as a custom map (meaning you would have several custom maps saved as engine and suspension maps)?
3. Yes, one advantage of the Multistrada's system is that you have four baselines (sport, touring, urban and enduro) which are customizable and stay the way you want until you mess with it again (but not to the detail of customization/variables the TV offers).
Lion is offline
post #7 of 7 (permalink) Old 12-16-2015, 10:49 AM
EvilSteve's Avatar
Hey Lion, that was my understanding as well, however, when you set an independent suspension setting, you still have to associate that suspension set with a ride mode. So, conceptually, you can change between several suspension sets (as well as the hard coded soft/medium/hard) BUT you only do that through the settings menu which you can't do while you're moving so, there are two problems here. First, if I want to change my suspension settings on any map, I need to stop and go to neutral (well, you don't *have* to stop, lol) in order to get into the settings menu. Second is that, when you go to change that suspension setting, you go to the "custom map" configuration which doesn't impact your stock rider modes.
For me, I think MV should ditch the "speed limiter" item on the dash and replace it with suspension settings which would then allow you to *ACTUALLY* change suspension modes on the fly. You *can* dynamically change loading modes (+passenger/+luggage) which, based on the fact that there's no electronic preload setting, makes exactly the same changes as a suspension setting change would so there doesn't seem to be any technical reason MV couldn't allow those changes.
Unlike Ducati's version of skyhook (remember, this is MV's version of the same system from Sachs), you don't set different settings for the load modes, you just click and they do magic. I've been told also that the MV system doesn't use clickers so, we're talking about a totally different way of configuring suspension which I'm only just getting my head around (you can have fast/soft, for example).
