2014 Rivale Warning Light Panel - MVAgusta.net
  • 2 Post By Arcimboldo
post #1 of 7 (permalink) Old 04-28-2018, 09:33 PM Thread Starter
I am having a very difficult time seeing/reading any of the warning lights on the long rectangular panel on my Rivale.
I thought maybe there is a dark tinted protective film on there from the factory that is removable -- but I cannot see any evidence of tab to peel it off. I can barely see it at night and during the day--forget about it. I am always forgetting to shut off my turn signals and feel like a total heel once I realize I have traveled 4 miles with my G.D, turn signal on!!!
Looking to confirm if this is normal for the Rivale
The MF'r from Cape Canaveral, FL
Present Bikes: Finally got everything I have always wanted.......almost
mjfields_228 is offline
post #2 of 7 (permalink) Old 04-29-2018, 08:37 AM
That should not be normal for any dash on any MV model.
I believe there should be instructions in the USER manual that you should have gotten with the Rivale to show how to change CONTRAST and BRIGHTNESS of the dashboard display.
I don't have this model bike, and I can't find a reference to use to check.
post #3 of 7 (permalink) Old 04-29-2018, 01:48 PM
colinpp's Avatar
I believe that he is having problems reading the warning lights not the dash display. The warning lights are quite small and not particularly bright, especially in bright sunlight. There is no option to increase the brightness. I regularly forget to cancel my indicators and have considered fitting a warning buzzer but I doubt I would hear it over the glorious sound of the bike.
Colin
___________________
2015 Rivale
2005 Aprilia RSV Factory
colinpp is offline
post #4 of 7 (permalink) Old 04-30-2018, 07:34 AM
Is the dash very different from a Brutale dash?
post #5 of 7 (permalink) Old 04-30-2018, 08:13 AM
Arcimboldo's Avatar
Red face
Same dash, if you mean yurp MY17 B3 or Dragster or Stradale BTW.
Kind of hairy to adjust the brightness of one LED via knob or SW settings.
But bending up the dash holder with the trusty Channellock water pump pliers
makes it way easier to read.
Dragster
Arcimboldo is offline
post #6 of 7 (permalink) Old 04-30-2018, 08:22 AM
Now I can see the issue...it looks like poor alignment of the illumination through the dash graphics.
post #7 of 7 (permalink) Old 04-30-2018, 08:47 AM
Arcimboldo's Avatar
Lightbulb
Yes but no.
Unless you are the hunchback Quasimodo, or a crayfish, you don't drive the Rivale with the eyes straight above the dash.
For average built people the parallax to the graphics and the LED is good.
Riding at night or with no sun, the dash lights are OK.
But in daylight the lip around the dash is not high enough to block the sunlight.
Hence tilting the dash somewhat more vertical fixes it cheap.
More or less...
Dragster
