B3 Suspension Settings - Page 7 - MVAgusta.net
post #61 of 65 (permalink) Old 05-15-2018, 06:37 AM
@mvferr: Can you please put your bike year and model in your signature though USER CP? Barring that, could you start your question with I have a _____(MY) ________(model) and .....
It will help us help you.
post #62 of 65 (permalink) Old 07-31-2019, 07:49 AM
Rohan Kilby's Avatar
[QUOTE=Pug;815402]Have read about others changing the suspension and having it done by "guru's" so perhaps we could start a listing to help others, or confuse?
I set mine up with trial and error over 5 months doing one small change at a time and is set for twisty tight mountain range riding, I am 85kgs ready to ride.
Measurements are listed by same method as per the owners manual.
I found the standard settings too soft for my liking, could get a bit of a wallow up but now is firm and stable and as a bonus it does not
headshake anywhere as much as before - no steering damper fitted.
Front
Preload = 9 turns
Rebound = 0.5 turn
Compression = 2.5 turns
Rear
Preload = 2 turns harder from standard approx 14mm of thread above locknut
Rebound = 1 turn
Compression = 1.5 turns
Hi mate Just starting to dial in my 2018 800rr suspension, I have ridden on factory settings so far up to Townsville from Brisbane and would like try and sort out a bit more compliance particularly in the rear as it is pretty harsh at present.i checked this thread and noted your post was a while ago have you found out anything new to add ?
I will sort rear sag out to start with, then mess with the front as per your suggestion riders weigh 80kg really looking forward to a run up the gillies 🤙 have you had much to do with bike craft in cairns they are apparently my service and warranty guys . My 750 F4 was the best handling motorcycle Iíd ever ridden till I got this new thing wow itís impressive and a ton of fun too.
Rohan Kilby is offline
post #63 of 65 (permalink) Old 07-31-2019, 02:20 PM
cherche's Avatar
I run the front as it is in the owners manual.
Quite satisfying.
But the rear was horrible, tried compression down to zero, had then to ad some rebound.
I ride a lot in the Italian Alps, streets there are somewhat "special", every few hundred 100 m you got different asphalt.
No way to have the rear adjusted to these conditions.
So I went for a Wilbers (German brand) rear shock.
Not stiff now, but much more feeling for the rear. Problems with short impacts on the back is solved - bike stays quiet. Does not behave like a Mustang...
And no pumping on the rear when hard on thottle - rebound still strong.
Still have the Andreani cardridges for the fork in the Garage, will put them in after rding season.....
2018 Brutale 800RR
cherche is online now
post #64 of 65 (permalink) Old 08-22-2019, 02:36 AM
Thanks Pug set mine up similar working well cheers mate.
post #65 of 65 (permalink) Old 09-03-2019, 03:25 AM
hi there
I'm using Ackers setup https://www.mvagusta.net/forum/815626-post3.html and it far more better than original setup. thanks.
but I have a problem with the forks... they are toooooooo soft, previoulsy I installed ohlins cartridges, but I wanted to sell the bike so I removed (and sell) and then I think I'm gonna stay a bit longer with the bike, so I would like to change spring and oil. Do you know where I can find springs for this model ? mine is a Brutale 800 2013.
thanks !
tommyx is offline
