There is probably still a small amount of air in your system. It only takes one little bubble to give a spongy feel.
Were your Master Cylinder seals leaking by, you would slowly lose pressure as you held the brake lever taught.
Some things to try:
Bleed at the upper banjo connection by cracking it slightly open, applying lever pressure carefully, tightening the connection, then releasing pressure.
With the reservoir cap off, "tap" the brake lever in very short staccato bursts and look for bubbles to release into the fluid. (This is a small motion)
Remove the calipers and push the pistons all the way into the caliper. Block them in place. Bleed the calipers while elevating them. Reinstall.
