Brembo "19RCS" or "19RCS Corsa Corta" - MVAgusta.net
  • 1 Post By Deano
post #1 of 6 (permalink) Old 05-04-2019, 01:42 PM Thread Starter
Hi,
I have a F3 675 (2016) and I would to change the master cylinders passing from Nissin to Brembo, in the specific way to Brembo 19RCS.
I noticed that now exists the 19RCS Corsa Corta and I would like to known what do you think about this product compared to "normal" 19RCS.
I don't use the bike on track but on street.
.fabioss. is offline
post #2 of 6 (permalink) Old 05-04-2019, 02:02 PM
if you are using it on MOSTLY or exclusively on the street the standard RCS is more than capable, hell even on track the standard 19 RCS is more than capable. The Corsa Corta, masters are generally the same thing, but with the ability to fine tune how the brake responds on initial engagement and feel.
I run the 19RCS on my F3 800, with the brembo stylema calipers, and it is insane braking power (amazing feel and power)... also ran the 19RCS with the standard M4 calipers and it was awesome.
2015 MV Agusta F3 800
2012 Ducati Panigale 1199S
2011 Triumph 675R
2009 Yamaha Road Star Warrior
jdgun is offline
The Following User Says Thank You to jdgun For This Useful Post:
post #3 of 6 (permalink) Old 05-04-2019, 05:24 PM
Deano's Avatar
I have the same setup on my 1078RR with the std. M4 calipers. As jdgun said, awesome braking street and track. Wasn't the fastest on track but I certainly out braked most. I thought about the Corsa Corta myself but it would be purely just to 'treat' myself. I think I'd get the stylema calipers first.
Deano
jdgun likes this.
2009 1078RR Brutale
Deano is offline
The Following User Says Thank You to Deano For This Useful Post:
post #4 of 6 (permalink) Old 05-06-2019, 09:18 AM
Just be sure if you are going to do some caliper upgrading at ANY POINT, do this as a package.. unless you are thinking just M4 calipers, which work with the sam master as your stock calipers.
The M50 calipers are a nice touch over the M4 calipers for my style riding, more feel and less sledgehammer initial hit.
You need to run a 17 RCS master, and the same 17 master works on the stylema calipers.
Best to try and think about the big picture to save the money on parts.
2011 Triumph 675R
jdgun is offline
post #5 of 6 (permalink) Old 05-06-2019, 12:18 PM Thread Starter
There is only a little problem, Brembo doens't have a clutch lever similar than brake lever mounted on 17/19RCS.
What could I buy as clutch lever to have the same look? I hate to have different lever between brake and clutch.
I don't want change the stock calipers.
Is it better the 17 RCS with stock calipers?
post #6 of 6 (permalink) Old 05-07-2019, 09:26 AM
If you are going to continue to use stock calipers, just get the 19RCS.
And yes there is a matching clutch lever and perch assembly, labeled as brembo, but built by Harris if memory serves, and there is just a lever they sell, but not sure on compatibility with the MV perch.
I personally use a CRG supersport fully adjustable perch, which allows 3 different leverage ratios, set it to easy pull and enjoy.
https://www.reactiveparts.com/brembo...th-switch.html
2011 Triumph 675R
jdgun is offline
