Help - Advice needed on upgrading 06 F4 Calipers/Rotors - MVAgusta.net
 4Likes
post #1 of 12 (permalink) Old 04-19-2019, 10:52 PM Thread Starter
Pbt
Pbt's Avatar
Greetings gentlemen,
I would like to upgrade the calipers and rotors on my 2006 F4 1000.
Please advise
Pbt is offline
post #2 of 12 (permalink) Old 04-20-2019, 08:14 AM
The first question is "why"?
post #3 of 12 (permalink) Old 04-20-2019, 09:38 AM
Rob Caso's Avatar
Because they suck.
Like mine do.
NTGmv1k likes this.
RC
Failure is not an option
2016 Tri Thruxton R
2005 Ago F4 1000
2005 BMW 1200GS
1995 Duc 916
1994 Bim DB2
1986 Duc MHR Mille
1983 BMW R100S
1975 Hon 400
1975 BMW R90S
1974 Duc 750 Sport
1972 Hon 750
1966 Hon S90
1965 Duc Monza
1971 Norton 750
1971 BMW R75
Rob Caso is offline
post #4 of 12 (permalink) Old 04-20-2019, 09:48 AM
Originally Posted by Rob Caso View Post
Because they suck.
Like mine do.
That's a great answer and it really helps to establish what the OP wants to dow with upgraded brake performance.......
post #5 of 12 (permalink) Old 04-20-2019, 10:12 AM
Rob Caso's Avatar
You mean like yours? At least mine answers a question.
There are no good options. An indictment of the Nissan setup is that a couple yrs later, MV went with a Brembo radial brake system which, in the case of an earlier F4, would require a complete front end change. The current system is a shocking setup for a $25k, 160 hp bike.
I replaced my pads with EBC's that Ferracci said would improve the braking. After having them milled to the proper thickness on a $20k machine to remove expensive pad material - oh yeah, the EBCs did not fit out of the box - the improvement was marginal at best. My amateur assessment is that it is probably the master cyl that needs to be changed to change the fluid volume at the actuating piston and therefore the brake force ratio going to the calipers. But I never did any of this. The current system is horrible and borderline dangerous.
RC
2016 Tri Thruxton R
2005 Ago F4 1000
2005 BMW 1200GS
1995 Duc 916
1994 Bim DB2
1986 Duc MHR Mille
1983 BMW R100S
1975 Hon 400
1975 BMW R90S
1974 Duc 750 Sport
1972 Hon 750
1966 Hon S90
1965 Duc Monza
1971 Norton 750
1971 BMW R75
Rob Caso is offline
post #6 of 12 (permalink) Old 04-20-2019, 10:26 AM
R1andrew's Avatar
I would ask if he as upgraded to better brake lines or master yet.
MV Agusta F4 Superleggera (Mona Lisa)
MV Agusta F3 Ago 2015
MV Agusta F4 1000 Senna #25
Ducati 1098 2009
R1andrew is offline
post #7 of 12 (permalink) Old 04-20-2019, 11:58 AM
The original equipment brakes were pretty state of the art back in 2005. They aren't dangerous...unless you are Mark Marquez and racing.
Bike came with steel braided hoses, so no real upgrade there.
Yes, compared to later brakes the axial mount Nissins are inferior, but they still stop the bike.
silentservice703 likes this.
post #8 of 12 (permalink) Old 04-20-2019, 02:51 PM
MV Arthur's Avatar
For around $1500 and some patience, you can convert to a radial front end setup.
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
MV Arthur is offline
post #9 of 12 (permalink) Old 04-20-2019, 03:24 PM
Back to the OP...why? What is your goal?
post #10 of 12 (permalink) Old 04-20-2019, 08:22 PM Thread Starter
Pbt
Pbt's Avatar
I want better stopping power.
I have a 17 Yamaha r6 dedicated track bike and I would like the F4 to behave similar.
Im aware the R6 weighs less , etc.
Would like to do a brembo caliper, master cylinder and rotors but need advice on models and part numbers.
I dont want to go overboard, simply to have more responsive brakes
silentservice703 and NTGmv1k like this.
Pbt is offline
