990R Front Brake Calipers - MVAgusta.net
post #1 of 12 (permalink) Old 05-20-2018, 07:38 PM Thread Starter
falcn's Avatar
Looking to replace the gold color calipers with either black or silver.
Are they 100mm spacing?
Looks like the M696/796 Brembo calipers are exactly the same calipers. I don't need more "braking" strength, they are good.
falcn is offline
post #2 of 12 (permalink) Old 05-21-2018, 12:05 AM Thread Starter
falcn's Avatar
https://commons.wikimedia.org/wiki/F...32_Caliper.jpg
The 696 uses the Brembo P4.32 and they look exactly like what is on my 990R, except for the color.
Can't find a call-out anywhere for the Brutale to verify they are P4.32 calipers.
falcn is offline
post #3 of 12 (permalink) Old 05-21-2018, 08:38 AM
UnaRosa's Avatar
Yes 100 mm spacing. I actually upgraded to monoblocs and bought off eBay. Brembo units were for a KTM but worked just fine. Only issue I ran into was the brake lines didn't work so had to order 1090rr line.
I can't definitively say the M696 units will work but believe they will especially if disc size is the same at 310mm.
Brett
"he's going the distance, he's going for speed"
'10 Brutale 990R ("Sophia")
'14 K1600GTL (Tour de Force)
'15 1290R (Torque monster)
'85 KZ700 (my first)
UnaRosa is offline
post #4 of 12 (permalink) Old 05-21-2018, 09:42 AM Thread Starter
falcn's Avatar
The disc size is 320mm on the 696 - but that is handled by the radial caliper mount spacing I thought - i.e. the fork caliper mount.
falcn is offline
post #5 of 12 (permalink) Old 05-21-2018, 02:00 PM
UnaRosa's Avatar
Sorry yes you are correct. Was in a hurry to get to work. If we were to step up to a 320mm, then would need to add spacers. Couldn’t handle the gold either so went with black.
UnaRosa is offline
post #6 of 12 (permalink) Old 05-21-2018, 02:42 PM Thread Starter
falcn's Avatar
Thanks.
falcn is offline
post #7 of 12 (permalink) Old 06-02-2018, 07:51 AM
Am I missing something? You're just looking to change the color, right? Can't you just get them powder coated? I had a pair done for $50 while I had them apart to rebuild them.
moocowman is offline
post #8 of 12 (permalink) Old 08-18-2018, 04:14 PM Thread Starter
falcn's Avatar
No, you're not missing anything. Brembo just doesn't recommend powder coating the calipers. With replacement calipers I don't have to wait for coating to keep riding, and I can sell the originals if desired.
I'll think about sending them off. Would need to previously find rebuild kits which adds more cost, unless the original seals/o-rings would be good.
falcn is offline
post #9 of 12 (permalink) Old 08-27-2018, 01:21 AM
Cars using Brembos come powder coated.....
post #10 of 12 (permalink) Old 08-29-2018, 11:27 PM Thread Starter
falcn's Avatar
From the factory.
I would just need to find a shop that knows how to properly tape the important stuff.
falcn is offline
