B3 rear shock upper mounting fork spacer? - MVAgusta.net
post #1 of 2 (permalink) Old 02-13-2018, 08:14 PM Thread Starter
Krossrider's Avatar
Can anyone tell me what the thickness of the spacer is?
Item #5 on the parts fiche
2014 B3 800
My bike appears to have been set up for very short and light weight rider, the spacer is missing, the forks were protruding enough to touch the handlebars and had a 7.5kg/mm rear spring fitted.
I'm currently fitting a 9.0kg/mm spring and noticed the spacer missing, the parts finder doesn't specify the thickness but interestingly there is different part numbers between the Dragster and Brutale.
2014 Brutale 800
Brisbane Queensland Australia
Krossrider is offline
post #2 of 2 (permalink) Old 02-20-2018, 03:28 PM Thread Starter
Krossrider's Avatar
d25d12sr4
I'm assuming OD 25mm, ID 12mm, thickness 4mm
2014 Brutale 800
