Brake pedal question - TV - MVAgusta.net
post #1 of 6 (permalink) Old 02-06-2018, 04:41 PM Thread Starter
MrG
My rear brake pedal seem really low and feels awkward using the rear brake . Does anyone know if you can raise the position of the pedal ?and if so how ?
MrG is offline
post #2 of 6 (permalink) Old 02-06-2018, 05:26 PM
Teeps's Avatar
Yes it's very easy.
Pull back on the clip-pin that secures the lower clevis to the pedal.
Loosen the nuts, one is left threaded as I recall.
Adjust the rod to make it shorter, which will raise the pedal.
Took about 5 minutes after I figured out how to release the clevis pin.
2016 Turismo Veloce 800
Teeps is offline
post #3 of 6 (permalink) Old 02-06-2018, 06:47 PM
airjawed's Avatar
Also, look into bleeding the system. Make sure your reservoir is not emtpy, can look full if the internal bladder is unfolded.
Do as suggested above but don't do too much at once. If you over turn it you will lock up the rear brake after it heats up... possibly.
airjawed is offline
post #4 of 6 (permalink) Old 05-25-2018, 06:43 PM
markammerman's Avatar
TV RC rear brake pedal adjustment
Originally Posted by Teeps View Post
Yes it's very easy.
My bike has a cover over the brake pedal assembly that goes on up to the structure that holds the pannier bags. Sorry for the obvious question but those big bolts just come right off and then remove the panel cover, correct?
markammerman is offline
post #5 of 6 (permalink) Old 05-25-2018, 07:03 PM
Teeps's Avatar
If you're talking the boot guard... that can stay in place.
Also, my bike does not have a center stand, so that might make the adjustment more difficult.
Teeps is offline
post #6 of 6 (permalink) Old 05-25-2018, 07:06 PM
Mine does have the center stand and I suppose thats the boot guard. Theres no access to any of linkage unless that cover is removed, I'll go eyeball it further! Thanks
