tire sizes - MVAgusta.net
post #1 of 20 (permalink) Old 01-18-2018, 04:40 PM Thread Starter
number2's Avatar
tire sizes
To all of you experts out there a question
If I go from a 190/55-R17 to a 190/50-R17 will I or should I notice any difference in handling and will the speedo read differently?
number2 is offline
post #2 of 20 (permalink) Old 01-18-2018, 04:58 PM
That's a 9.5 mm drop in rear height. It'll slow steering a bit unless you drop the front the same.
Will you notice it? That depends on how in tune you are with your machine.
post #3 of 20 (permalink) Old 01-18-2018, 04:59 PM
Teeps's Avatar
Go here: Tire size calculator
Enter each size in the box but on two lines.
Click calculate and see the results.
Teeps is offline
post #4 of 20 (permalink) Old 01-18-2018, 05:15 PM
Maximum Velocity's Avatar
That will barely be Noticeable. I mean... If it is a new tyre that will give you already a bigger difference in feel.
What a beast of a motorcycle!
Maximum Velocity is offline
post #5 of 20 (permalink) Old 01-18-2018, 06:24 PM Thread Starter
number2's Avatar
so what size front tire is compatible with a 190/50? Typically I run a 120/70-17
number2 is offline
post #6 of 20 (permalink) Old 01-19-2018, 02:14 AM
Bumpkin's Avatar
Be wary of using tyre sizes not specified by the manufacturer. It's an easy win for an insurer to deny an accident claim.
Bumpkin is offline
post #7 of 20 (permalink) Old 01-19-2018, 03:43 AM
dansoarr's Avatar
120/70-17 is a standard match for the 190.
Apart from the obvious change in effective ride height and circumference circa -3%, typically you will find that the rear profile shape will change slightly. The 190*50 profile will, while having the same nominal width as the 190*55, exhibit a 'nominally' shallower profile than the 190*55 that will have a more noticeable effect that the pure circumference difference when upright. This will effect the rate at which the bike turns in or drops into the bend i.e slow it down, so combined with the drop in rear ride height (assuming you don't compensate) it will be noticeable. Racing on these sizes at the start of last decade (oh i'm getting old) moving to the 55 from the 50 on a 6" rim the effect was very noticeable, as it had the reverse of what you will see.
Caveat, all 190*55's etc do not have the same profile shape. If you think back to the early Michelin Pilot Power Race the profiles were very sharp almost a V compared to the Pirelli Super Corsa and Metzler at the time.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #8 of 20 (permalink) Old 01-19-2018, 08:49 AM Thread Starter
number2's Avatar
now that I am armed with all this extra knowledge, I am more confused . Thanks guys. Since I am only doing casual riding it should not make much difference to me
number2 is offline
post #9 of 20 (permalink) Old 01-19-2018, 08:50 AM
I'm sorry but this is simply not true in the UK.
For an insurer to avoid liability it must demonstrate that both the modification was deemed material (and was not disclosed to them) and that it contributed to the incident.
If you fit the wrong speed rating, different story, but a slightly different profile or width matters no a jot (to the insurer).
Hawk is offline
post #10 of 20 (permalink) Old 01-19-2018, 08:52 AM
Oh, have we had this discussion before. There is tire "shape" (round, elliptical, and triangular) and there is tire "profile" (190/55, 120/70, 190/55, 170/65). The two are not really related.
The sidewall height change should not affect the tire's "shape". If you look at a t 190/55 v. 190/50 tire of the same style, i.e. Pirelli Supercorsa, the "shape of the tire from sidewall to sidewall should not be different. Now, spoon a tire meant for a 6" rim onto a 5.5" rim and you will change that shape.
New tires by nature have better tip in feel because their shape has not been altered by road use (i.e. flattened).
