TV Rear Brake Pedal - MVAgusta.net
  • 2 Post By AJL 62
post #1 of 4 (permalink) Old 01-16-2018, 02:03 PM Thread Starter
TV Rear Brake Pedal
Hi has anybody adjusted the rear brake pedal rod to lift the front of the pedal if so could you let me know how much of the bike I have to take apart to slacken the adjusting nut, thanks. Andre
AJL 62 is offline
post #2 of 4 (permalink) Old 01-16-2018, 03:28 PM
Teeps's Avatar
Yes, had the same complaint with my new 2016 TV.
No disassembly is needed, took about 5 minutes after I figured out how free the clevis pin.
The clevis pin has a spring clip that clips onto the clevis and secures it in place.
First loosen the nut.
Then move the clip toward the rear of the bike to release its grip on the clevis, then slide the peg out.
Turn the clevis clockwise to raise the pedal.
Please include your location in the profile.
Teeps is offline
post #3 of 4 (permalink) Old 01-16-2018, 04:23 PM
MarcSilverTriple's Avatar
If not enough range of setting with the standard pedal, you may consider CNC Racing gearshift and brake pedals with foldable toe pegs. Setting of the toe peg is based on an excentric and you gain +/-1 cm from the standard available position. For me it completely changed the rear brake and it transformed it in an usable one.
Marc,
Turismo Veloce in France
MarcSilverTriple is offline
post #4 of 4 (permalink) Old 01-17-2018, 10:34 AM Thread Starter
Thanks guys for your assistance, all done, much better. Andre
Teeps and Teeps like this.
AJL 62 is offline
