Rear linkage pivot point - MVAgusta.net
post #1 of 10 (permalink) Old 01-13-2018, 07:28 AM Thread Starter
V4mP's Avatar
Hi,
I'm building Cagiva V-Raptor with MV Agusta swingarm.
I've a plan to use MV Agusta linkage. Can someone take some measurements for me? If possible take measurements when bike is straight not on a sidestand.
In the picture are measurements I need.
Y1 =
Y2 =
Y3 =
X1 =
A1 =
Don't ride faster than your angels can fly !
V4mP is offline
post #2 of 10 (permalink) Old 01-20-2018, 07:29 AM Thread Starter
V4mP's Avatar
Come on guys tape measure is accurate enough at this point.
I tried to use CAD program to get those measurements.
From same pictures as I posted previously I got these measurements can any one verify are they any close?
Y1 = 316mm
Y2 = 425mm
Y3 = 601mm
X1 = 41mm
A1 =
From swingarm pivot point to wheel center = 550mm
V4mP is offline
post #3 of 10 (permalink) Old 01-20-2018, 08:04 AM
@V4mP: First, you have to realize that someone has to disassemble their bike to a certain point to get you these measurements. Then you have to hope the person that decides to undertake that is reasonably competent....then, of course, half the world i buried in ice and snow right now. My bikes, for instance are packed away in a trailer on battery tenders and covered. Ergo, I'm not attempting this now. In June, maybe....
post #4 of 10 (permalink) Old 01-21-2018, 03:32 AM Thread Starter
V4mP's Avatar
I know it is winter and it makes things more complicated.
But you don't have to disassembly your bike to get those measurements. Is the picture I posted little bit misleading?
Measurements doesn't have to be from F4 older Brutales (prefacelifted) works just fine.
V4mP is offline
post #5 of 10 (permalink) Old 01-21-2018, 07:02 AM
Yes, it was misleading. I believe the geometry is different F4 to B4.
post #6 of 10 (permalink) Old 01-21-2018, 07:09 AM
So, to clarify, you want Y3 = The height of the shock mount, Y2 = The height of the swingarm pivot, A1 = The distance center-to-center of the swingarm pivot to the shock mount, X1 = The horizontal center-to-center distance between the shock mount and the swing arm pivot, and Y1 = the height of the centerline of the rear axle.
post #7 of 10 (permalink) Old 01-21-2018, 09:16 PM
The geometry of F4 and B4 frames is the same, F4s have steering damper and fairing mounts that B4s don't
B4 frame plates have muffler mounts on both sides, F4s only on the right
The only dimensions that are fixed......
The distance between the swing arm pivot and the linkage toggle pivot
The distance between the swing arm pivot and the lower shock mount
The length of the shock, unless you are using an adjustable length shock
Everything else moves depending on.......
Tire size
Fork stanchion height
Swing arm adjusted length
Ride height
You have 3 good fixed points
Center of the engine mount bolt in the head
Swing arm pivot point
Linkage toggle pivot point
What the fuck do I know?
Frame designer for F.W. Egli
World Endurance Racing Manufacturers Champions '69-'74
10 of those blue FIM Certificates hanging in the front window of a little Swiss farmhouse
post #8 of 10 (permalink) Old 02-07-2018, 01:12 PM Thread Starter
V4mP's Avatar
Yes.
V4mP is offline
post #9 of 10 (permalink) Old 02-07-2018, 01:28 PM Thread Starter
V4mP's Avatar
So are you willing to take some dimensions.
You might be competent enough.
V4mP is offline
post #10 of 10 (permalink) Old 02-17-2018, 07:35 PM
Go back and reread my last post.......you weren't paying attention last time
