Fork oil... this is not looking too clean- comments please! - MVAgusta.net
 2Likes
  • 2 Post By MV Arthur
  • 2 Post By Eljono
post #1 of 9 (permalink) Old 01-02-2018, 02:19 PM Thread Starter
Eljono's Avatar
So Eljonos fork workshop is in full effect, in our laundry room (hush, or the missus will hear us!)!
Now, check out this funky oil removed from the LH/rebound leg. It looked reasonably good while pouring out from the main chamber, but once I started pumping the dregs out of the cartridge, it turned to this. Pic 1 side on, pic 2 taken through bottom of clear container, with ceiling light above.
Is it normal to find this amount of crud?
Jonathan
Southern Norway
Eljono is offline
post #2 of 9 (permalink) Old 01-02-2018, 02:27 PM Thread Starter
Eljono's Avatar
Update: the preload spacer is made of cheapo plastic, and the ends are not chamfered. Looking st below pic, looks like the spring bottom has been grinding away at it.
Plausible explanation?
Jonathan
Southern Norway
Eljono is offline
post #3 of 9 (permalink) Old 01-02-2018, 02:28 PM
MV Arthur's Avatar
Likely brake dust and road debris that accumulated on your fork leg and risen up past the seals.
GCBC and GCBC like this.
2013 F4RR
2009 F4 RR 1078 312
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
MV Arthur is online now
post #4 of 9 (permalink) Old 01-02-2018, 02:32 PM
GCBC's Avatar
I presume your doing a cartridge upgrade kit? what tools are you using? Im planning on doing this pressurized ohlins kit myself and need the specific tools.
MV F3 for sale with all the goodies. will ship international
GCBC is offline
post #5 of 9 (permalink) Old 01-02-2018, 02:41 PM Thread Starter
Eljono's Avatar
Brake pad dust might just be spot-on! Certainly fits with the fineness of the suspended particles!
Also, I almost lost the leg out of the sleeve when I turned the leg upright after emptying it first time, which may have pulled some of it past the seal. Will investigate, but Iím not excited at the prospect of a full tear-down and clean of cartridge and all!
Jonathan
Southern Norway
Eljono is offline
post #6 of 9 (permalink) Old 01-02-2018, 02:49 PM
MV Arthur's Avatar
Not sure which bike you have but on the F4 there's a big c clip retainer that secures the leg at full extension. So no need to worry unless you're doing it over a glass table!
2013 F4RR
2009 F4 RR 1078 312
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
post #7 of 9 (permalink) Old 01-02-2018, 02:58 PM Thread Starter
Eljono's Avatar
After very, very nearly forking out for a Mupo LCRR kit, I actually got a grip on myself, forked out the cash for a new rear shock with all bells and whistles instead, and elected to change only springs and oil in the fork, since it already has a fair bit of adjustability. THEN change to cartridge when I still yearn for more, lol!
All kidding aside: my 4 year old forks came apart very easily.
You will need, assuming Marzocchi 43mm USD with preload comp and rebound adj:
22mm spanner or socket (preload adjust)
32mm for top cap (bought a pro works plastic ring spanner for this, but with care should be able to loosen it without marking)
19mm spanner for inner piston lock nut.
Tool to separate spring from lock nut - make yourself or be lazy and buy a plastic one like me. This is a must unless you have 4 hands. You will be able to pull down the spring manually.
Once youíve poured out oil, spring andpreload spacer, the cartridge will come out by loosening the 6mm hex at the fork bottom.
Thatís all you need, as inferred by Ed in a separate post when i posed the same question
Jonathan
Southern Norway
Eljono is offline
post #8 of 9 (permalink) Old 01-02-2018, 05:44 PM
Maximum Velocity's Avatar
A 2014 flat-bar, naked F3-like thingy with mx-style rear.... Got it?
What a beast of a motorcycle!
Maximum Velocity is offline
post #9 of 9 (permalink) Old 01-03-2018, 02:15 AM Thread Starter
Eljono's Avatar
.. there's a big c clip retainer that secures the leg at full extension...
C clip confirmed!
Lol at the glass table... I can just imagine!
Jonathan
Southern Norway
Eljono is offline
