F3 Ohlins Cartridge install tools for DIY? - MVAgusta.net
  • 2 Post By Wildfire
post #1 of 2 (permalink) Old 12-29-2017, 02:49 PM Thread Starter
GCBC's Avatar
Decided im going to do the cartridge install myself. Ive seen a few youtube videos on other bikes and they don't look to have any expensive tools for the job on them. Im sure you can spend a ton on fancy tools but there are cheaper tools available im sure.
Can someone please list the tools that they used to actually do this job? Im going with the fkr100 pressurized kit for it and already have a full race car shop of tools but no suspension related equipment. obviously I have a vice and stands to hold things, just need the actual tool list.
thanks
have the nitron race pro on order for the rear and that will be an easy swap im sure.
MV F3 for sale with all the goodies. will ship international
GCBC is offline
post #2 of 2 (permalink) Old 12-30-2017, 09:46 AM
Wildfire's Avatar
I fitted my Ohlins fork internals. It was fairly easy. The main thing you''ll need is the Ohlins fork cap tool to screw the caps in and a spring comressor tools. The rest is pretty easy, 14 or 15mm spanners if I recall correctly. If you don't mind spending then a compressor kit is about 30 or so in the UK. We just made up a little steel stop that hooks in place when fitting the spring. Something like this http://www.reactivesuspension.com/pr...category_id=10
My dad made an air gap tool to set the oil level and I went with this.
Some say you need Ohlins fork seals, but I don't think this is necessary. You should use Ohlins fork oil though.
Took me aboout 3 hours once I worked out what I was doing. However my kit cams straight out of another set of forks, from my friend's race bike which caused a few issues as I needed to take the springs out of the kit to pump them up.
Rear shock is very, very easy especially if you have an Abba stand.
GCBC and GCBC like this.
Wildfire is offline
