Rebuilding Brembo M40s - MVAgusta.net
 2Likes
  • 2 Post By silentservice703
  • 2 Post By theknurl
post #1 of 7 (permalink) Old 09-24-2017, 02:55 AM Thread Starter
PTsalas's Avatar
Hi guys,
I managed to get a set of Brembo M40 calipers from a 2012 F4 that was stripped for parts. The calipers are in good conditions, but since they have been laying around for some years I question the integrity of the seals.
Before I install the calipers on my 2012 F3, how difficult is it to take the calipers apart and replace the seals? (Ive done fork seals myself), I didn't notice anywhere in the manual the process to replace the seals and take apart the pistons...
Any special tools needed?
I plan to get this kit:
MV Agusta F4 998 R front brake caliper seal repair rebuild kit 2012 12 | eBay
Advice, comments
Thanks!
PTsalas is offline
post #2 of 7 (permalink) Old 09-24-2017, 06:40 AM
The pistons in the caliper just pop right out with a little help from compressed air.
There is nothing that holds them in the body of the caliper except for friction with the seals.
PTsalas and PTsalas like this.
post #3 of 7 (permalink) Old 09-24-2017, 09:42 AM Thread Starter
PTsalas's Avatar
Thanks, is there any grease needed on the seals when putting it back together?
PTsalas is offline
post #4 of 7 (permalink) Old 09-24-2017, 05:14 PM
PTsalas;
Save your money, the seals will be fine
Rinse the calipers out with fresh DOT 4
Mount and bleed
post #5 of 7 (permalink) Old 09-25-2017, 07:28 AM
There is a red grease made for brake systems, but I just use DOT4.
post #6 of 7 (permalink) Old 09-25-2017, 11:45 AM Thread Starter
PTsalas's Avatar
PTsalas;
Mount and bleed
I had some fun blowing out the pistons with compressed air, the residual DOT 4 kept the original seals lubricated and all looks good.
Will clean up the pistons put back together. Thanks guys.
PTsalas is offline
post #7 of 7 (permalink) Old 09-26-2017, 05:31 AM
I probably should have cautioned you on just how far those pistons can pop!
