No rear brake on my F4 - MVAgusta.net
 7Likes
post #1 of 28 (permalink) Old 09-18-2017, 05:35 PM Thread Starter
number2's Avatar
I recently changed my rear brake to an aftermarket replacement and it seemed to be working fine. Then one day there is zero brake function. I bled the brake and managed to get good pressure, rode the bike and it was ok. Came back a few days later and again no brake. I mean zero pressure. I looked for signs of fluid but nothing so before I bleed it again anyone have any ideas.
number2 is online now
post #2 of 28 (permalink) Old 09-18-2017, 05:43 PM
Hmmm...Sealed system. No leaks. Where does the reservoir port into the master cylinder? Vertical or to one side? Bleed again and pay attention to volume of bubbles. A lot or just a tiny amount?
You didn't use a pneumatic bleeder did you? High line pressures will generate microscopic bubbles in the fluid which will join together after a short time to create mushy brakes. Most pneumatic bleeders call for less than 90 psi.
post #3 of 28 (permalink) Old 09-18-2017, 08:17 PM Thread Starter
number2's Avatar
I removed the caliper and held it higher than the master cylinder, pumped the pedal and released the pressure, then repeated until there was pressure. Will do it again
post #4 of 28 (permalink) Old 09-18-2017, 11:12 PM
George;
Remove the caliper, hold it low with the line fitting at the high point, push the pistons all the way back in
Remount caliper
Now all the air is in the MC, now loosen or remove a bolt on the MC and rotate it so the pushrod end is highest
Push the lever repeatedly, slowly, the piston will expel all the air through the return port
Been doing it like this since I was a kid
Think like a bubble
ceepee likes this.
post #5 of 28 (permalink) Old 09-20-2017, 02:11 PM Thread Starter
number2's Avatar
I understand the bubble reference which is what I was trying to do. If there was air in the line it should have been removed. Still cant figure out why all the pressure went away
The Following User Says Thank You to number2 For This Useful Post:
post #6 of 28 (permalink) Old 09-20-2017, 02:46 PM
If the piston seal is leaking by from the pressurized to the unpressurised side it will feel like no pressure.
esq'z me, esq'z me, Mixon and 1 others like this.
post #7 of 28 (permalink) Old 09-21-2017, 06:16 AM
Yep....if no fluid leak and properly bled then the master cylinder cups are not sealing.
post #8 of 28 (permalink) Old 09-21-2017, 07:17 AM
Mixon's Avatar
Have you removed the dust boot? If the piston seal is leaking you'll find fluid behind the boot.
I've got a big bag of copper washers. Let me know if you need some George
Mixon is offline
post #9 of 28 (permalink) Old 09-21-2017, 07:26 AM Thread Starter
number2's Avatar
I took the master cylinder apart last night and am having trouble figuring out how air is removed from the piston cavities. Fluid goes in one side and is supposed to flow to the other cavity but there is no place for the air to escape or be bled off other than where it enters. I don't know, maybe I am missing something since I am not an engineer.
post #10 of 28 (permalink) Old 09-21-2017, 12:48 PM
George...this explains everything, even if it is a car drum system described, the master cylinder piston works the same way.
