Rear brake - MVAgusta.net
 2Likes
post #1 of 11 (permalink) Old 08-14-2017, 01:06 PM Thread Starter
V4mP's Avatar
Rear brake
Hi!
I ride Cagiva V-Raptor with MV Agusta single sided swingarm and I've problem with rear brake caliper which doesn't fit.
Rear brake caliper bracket fits swingarm and has same bolt pattern as brake caliper, but when bracket is mounted to swingarm I can't mount caliper.
There isn't enough space for bolts. So the question is, is there differences in rear brake calipers/brackets between model years?
Don't ride faster than your angels can fly !
V4mP is offline
post #2 of 11 (permalink) Old 08-14-2017, 10:32 PM
cruiser's Avatar
Do you have some photos to share ?
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
post #3 of 11 (permalink) Old 08-15-2017, 12:12 PM Thread Starter
V4mP's Avatar
Well... of course not.
I'll try to get some pictures.
V4mP is offline
post #4 of 11 (permalink) Old 08-16-2017, 02:34 AM
MVAgusta.net Sponsor
mitchy's Avatar
It was a pretty simple question,provide some photos so we can help you.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
post #5 of 11 (permalink) Old 08-16-2017, 07:57 AM
And what model MV swing arm are you using? And what caliper and mounting bracket?
post #6 of 11 (permalink) Old 08-16-2017, 03:50 PM
Simple.....
Rotate the hub 180 so the axle is on the bottom
post #7 of 11 (permalink) Old 08-17-2017, 08:53 PM
Ed;
The rear Nissin caliper is lopsided so is the mounting bracket
1st and 2nd Gen are the same, except 2nd Gen ones have the ABS sensor and the slot for the brake stay pin is only 31mm long, 1st Gen slots are 35mm long
He has the hub upside down
post #8 of 11 (permalink) Old 08-20-2017, 01:28 PM Thread Starter
V4mP's Avatar
Simple.....
Has not come to mind that I might have hub mounted hub upside down.
Should hub rotate 360 or do I need to remove it?
V4mP is offline
post #9 of 11 (permalink) Old 08-20-2017, 05:10 PM
180 the axle must be on the bottom
No need to remove it, just rotate it and mount caliper
post #10 of 11 (permalink) Old 01-13-2018, 07:42 AM Thread Starter
V4mP's Avatar
Problem solved! Thank you.
V4mP is offline
