Brembo Monoblock ,check Banjo
Well after stuffing around with Radial brakes and new lines ,I still was not happy with the feel ,Well i have no idea why Brembo would only drill a .05 mm hole in the brembo disc brake banjo bolt , I drilled it out to 1.5mm on both brembo disc brakes and had an amazing difference in grab .Anyone know why Brembo would make a banjo bolt with such a small outlet flow ,most banjo bolts on many other bikes are around 1.5mm hole to 2mm hole .So before you change master cylinder ,brake pads ,lines and all the other parts ,change the Banjo bolts first . Only the bolts guys .Might just get rid of that wood feeling.
cheers eddy
