Nissan brake master cylinder ,is this faulty. - MVAgusta.net
post #1 of 5 (permalink) Old 07-16-2017, 05:42 AM Thread Starter
eddypro's Avatar
Need the experts please ,I am pretty sure there should be 2 holes all the way ,one looks wrong and might be a manufacturing issue ,Guys can anyone confirm this or has an old one lying around that could take the reservoir off.I have asked Deano on another thread to check but he might not see it. crc nissan master brake cylinder
cheers eddy
eddypro is offline
post #2 of 5 (permalink) Old 07-16-2017, 09:26 AM
number2's Avatar
isn't there supposed to be a screw in one of those holes
number2 is online now
post #3 of 5 (permalink) Old 07-16-2017, 04:01 PM Thread Starter
eddypro's Avatar
Screw in the big hole , holds the reservoir, its the small hole I am talking about , does not seem correct
eddypro is offline
post #4 of 5 (permalink) Old 07-16-2017, 06:27 PM
Deano's Avatar
Eddy,
Same as mine. If you look real close you'll see a very small hole goes all the way through, I can see it in your picture. If you put the piston back in and gently pump the lever you will see fluid in/coming out of this hole. Most master cylinders I've seen have this 'pin' hole to let air out on the backstroke. It's small, I have a set of finger drills and my smallest (0.75mm) is just too big. It'll be drilled that way to save punching such a small drill through the full wall thickness, ie. countersink with the bigger drill then drill through with the pin hole.
Deano
Deano is offline
post #5 of 5 (permalink) Old 07-16-2017, 07:16 PM Thread Starter
eddypro's Avatar
Thanks Deano ,I stuffed it anyway ,So Don't drill it ,I will put up Looking for another one in the wanted section . Always learning or maybe im just impatient .
eddypro is offline
