Front Brakes on 2010 Brutale 1090RR - MVAgusta.net
post #1 of 25 (permalink) Old 07-09-2017, 11:32 AM Thread Starter
jrebollo's Avatar
Hi,
I recently purchased a 2010 Brutale 1090rr, the bike has 13k miles and it runs great. The only issue is that the front brake feel weaker than I expected. My previous bike was a 2006 honda cbr 600f4i, and the brutale brakes don't feel better than the honda's brakes. When I come to stop sign and I'm going about 30mph and I only use the front brakes to stop I have to push the lever hard to come to a full stop. Is this normal? The previous owner did not ride it much, he did replaced the brake fluid about 6months ago. Could the pads be bad? What do you think? How strong are the brutale's brakes supposed to be?
Thanks!
jrebollo is offline
post #2 of 25 (permalink) Old 07-09-2017, 11:58 AM
Bleed the brakes and you should be able to do stoppies easily.
post #3 of 25 (permalink) Old 07-09-2017, 12:52 PM
My 910R front brakes became quite wooden in feel after quite a few miles. Still material left, just no feel. I flush and bleed my brake fluid at least every 2 years.
Installed some new EBC HH pads and ...voila!! that good hard bite returned.
post #4 of 25 (permalink) Old 07-09-2017, 06:59 PM
Deano's Avatar
Master cylinder is crap. Was always bleeding mine. New pads helped for a while then it was back to wooden feel and more bleeding. Changed to a Brembo 19RCS and the brakes were finally as good as they should be. I rode a mate's 2014 1090 and nearly got into some serious trouble with braking. Expensive fix but well worth it, best aftermarket thing I've put on.
Deano
Deano is online now
post #5 of 25 (permalink) Old 07-09-2017, 09:22 PM Thread Starter
jrebollo's Avatar
Thanks for all the good information. I think I will get new break pads, and see how it goes. The breaks were bleed 600 miles ago at the MV dealer
jrebollo is offline
post #6 of 25 (permalink) Old 07-10-2017, 01:54 AM
cruiser's Avatar
Were the brakes bled to replace the brake fluid or for another reason? Were new Sintered pads or Organic pads used ?
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
post #7 of 25 (permalink) Old 07-10-2017, 02:35 AM
eddypro's Avatar
Yep Deano is spot on ,mine have gone back to that wooden feel ,im over it. Deano did you change the brake lines ?
cheers eddy
eddypro is offline
post #8 of 25 (permalink) Old 07-10-2017, 04:54 AM
Deano's Avatar
Eddy,
No I didn't although I almost bought mmmmm's Frentubo lines but didn't want separate lines just for the neatness of the originals. In hindsight it might have made them even better, especially in the bleeding department. Did a ride day at Qld. Raceway in March and while I may have been one of the slowest in my class I outbraked everybody. They are absolutely brill with the Brembo 19RCS wet or dry.
Deano
Deano is online now
post #9 of 25 (permalink) Old 07-10-2017, 07:32 AM Thread Starter
jrebollo's Avatar
The brakes were bled to replace the fluid. No idea what pads are in there or how old they are, I'll have to check
jrebollo is offline
post #10 of 25 (permalink) Old 07-10-2017, 07:35 AM
eddypro's Avatar
Ok Thanks Deano i will get it , My Gs 1200 brakes blows the Mv away in the braking Department
thanks
eddypro is offline
