front preload settings on TVL - MVAgusta.net
post #1 of 14 (permalink) Old 06-07-2017, 03:15 PM Thread Starter
Hi ALL,
I still have troubles with my front suspension ...
The fork starts "bouncing/weaving" from 170kms/h with the windshild up ! less when it's down actually ...
I checked for the front & back preload settings in TVL Owners Handbook but I did not find them.
Not sure how the previous owner adjusted them so, I just want to put them back to default, just to try ..
Who can help me to set them back to default ?
FYI, tires are new and pressures are fine.
THX
philoutch is offline
post #2 of 14 (permalink) Old 06-07-2017, 03:49 PM
Originally Posted by philoutch View Post
Hi ALL,
THX
Detail can be found below
http://www.mvagusta.net/forum/56-sus...uspension.html
mickr69 is offline
post #3 of 14 (permalink) Old 06-07-2017, 03:59 PM
Arcimboldo's Avatar
Talking
...I checked for the front & back preload settings in TVL Owners Handbook but I did not find them.
Looks perfectly clear to me.
I'm just back from BCN
the TV is a month old and over 6 000 km
apart from wind buffeting near van, crate-shaped SUV or camper it doesn't float or anything.
The front shocks are even surprisingly good.
OK the Stradale was much better.
The road to Castellar de n'Hug being a test for suspension, chassis and tires.
Dragster 800
Arcimboldo is offline
post #4 of 14 (permalink) Old 06-07-2017, 04:00 PM
MarcSilverTriple's Avatar
Originally Posted by mickr69 View Post
This is for the TV/TV Ed1. TVL is sightly different. Attached then remove the scan as Arcimboldo just put a clearer one. a minute before my post.
Marc,
Turismo Veloce in France
Ride with us in Vosges :
Last edited by MarcSilverTriple; 06-07-2017 at 04:17 PM. Reason: remove the attachement as Arcimboldo put the same earlier.
MarcSilverTriple is offline
post #5 of 14 (permalink) Old 06-07-2017, 04:15 PM
Grilled probably from a few second, as my first upload did not worked. I'm not sure why the front shocks got so bad press as well on the TV. Have no complains on it. I have no clue for the TVL, but I made the comment earlier that preload is what is not set electronically on the TVL, and it may be worth considering adjustment... Sport mode rules, maybe
Marc,
post #6 of 14 (permalink) Old 06-07-2017, 07:19 PM
Fastspy's Avatar
On the topic of the front forks, has anyone attempted to adjust the forks in the triple clamps to an alternative position (either up down)?
I just looked at my TVL and noticed that my forks are positioned in the triple clamps lower or slid down (only 1 line showing above the top triple clamp) than the photo posted above showing the front pre-load location on the bike.
I've used fork position on my enduro for offroad use to accommodate the ride environment (ie lower forks for the sand dunes to chopper it out) and raise the forks for single track to improve steering quickness and precision.
My forks on the TVL have not been adjusted by me but they appear to be in a different position than the photo indicates for preload setting location.
Guess I need to dig into the shop manual and see what I can find about fork height and to determine what stock position should be.
Fastspy is online now
post #7 of 14 (permalink) Old 06-07-2017, 07:41 PM
Fastspy's Avatar
follow up from the shop manual..
Appears that the fork height differs between the TV and TVL. I copied the page in the shop manual for positioning the forks in the triple clamps after servicing.
Took a quick measure and my TVL is set at 237 MM however at this position they differ from what the owners manual shows for position in the photo when referencing the preload location.
post #8 of 14 (permalink) Old 06-07-2017, 11:28 PM
husky511's Avatar
hi
on topic.
i think, that teh front suspension is to soft. i made the spring preloade, 4.5 turns harder, but is no enough...
you have the same feeling?
Marcel
Courrent Bikes:
Aprilia Tuono V4 1100 Factory / 2016
MV Agusta Tourismo Beloce / 2016
husky511 is offline
post #9 of 14 (permalink) Old 06-08-2017, 01:43 AM Thread Starter
Originally Posted by husky511 View Post
hi
on topic.
Marcel
THX for ALL the replies Guys !
Well, it seems that I've got TV/TV-ED1 handbook, that's why.
Just to be sure ... I think I have to start from "open" position and turn clockwize for both, right ?
Back from a 2700kms trip in Sardinia, apart from the GPS fault I was always in trouble with my suspensions, Fully loaded or not I never managed to get them as I like, always too soft for me, especially the front.
There is really room for improvement on that topic in my opinion !
post #10 of 14 (permalink) Old 06-08-2017, 05:31 PM Thread Starter
stil not sure about the standard position for the rear ... counterclockwise to the end or in the middle of the graduations ?
THX
