Rosso 3, track pressure - MVAgusta.net
post #1 of 8 (permalink) Old 06-06-2017, 02:12 AM Thread Starter
I'm gonna drive into a track next Sunday 11 I'm wearing a rosso III, which pressures do you recommend for track practice ? thanks !
tommyx is offline
post #2 of 8 (permalink) Old 06-06-2017, 05:32 AM
The blanket answer tends to be a few psi less than you ride on the road but there are lots of variables.
Hawk is offline
post #3 of 8 (permalink) Old 06-06-2017, 07:18 AM
Deano's Avatar
I run Dunlop Q3's. At a recent ride day I ran 28-30 rear and 30-32 front. Usually 32 rear, 34 front for the road. No issues but as tommyx said there are variables. Air temp on the day was 27C, light breeze. No idea of the track temp. Stuck like shit to a blanket. Needed bigger balls to test their limits.
Deano
Deano is online now
post #4 of 8 (permalink) Old 06-06-2017, 08:02 AM
Another thing to consider is that tire pressures are usually set when cold. Riding the bike to the track will change your tire temp.
I'd ask someone that knows that track what they recommend. A track professional should have an answer.
post #5 of 8 (permalink) Old 06-06-2017, 10:16 AM
Qfactor's Avatar
From memory from pirelli track vendor back in the Corsa III days
Corsa III:
Cold pressures
30psi F
31psi R
I like a squishy rear and used to run ~30psi rear
Q
Qfactor is offline
post #6 of 8 (permalink) Old 06-06-2017, 10:26 AM
Pace, track temps, and weather conditions are going to play a big role. Will there be a Pirelli vendor at the track day? It's always best to make friends with the local tire guys. They have a ton of information, and I've always found the Pirelli guys know their stuff.
Fat Pat is offline
post #7 of 8 (permalink) Old 06-14-2017, 02:28 AM Thread Starter
Hi there !
Thanks everybody for your answers.
finally I set them to 2.1 front, 2.0 rear, about 30.9 front, and 29,4 rear
https://duckduckgo.com/?t=lm&q=psi+atmosphere&ia=answer
Everything was ok, lots of fun and the wheel was worn correctly
tommyx is offline
post #8 of 8 (permalink) Old 06-14-2017, 06:59 AM
Nice result!
