Does this front tire wear seem unusual? - Page 4 - MVAgusta.net
 4Likes
post #31 of 38 (permalink) Old 02-19-2017, 06:54 AM
All good for the Bridgestone product....Michelin, being French, is different and softer....
post #32 of 38 (permalink) Old 02-19-2017, 07:25 AM
Originally Posted by fingertight View Post
So I'm confused now...not the first time. Are you agreeing it's not road crown that makes the uneven wear? Just from the first picture on the first thread it's obvious it's not. That would need to be about 30 to 35 degree crown to get that wear. Anyway, I appreciate all the good advice from everyone. Love you still Snark.
Somehow, my response to this didn't post....not the first time. I seem to forget to push the Submit Reply button. Crazy.
Anyway, yes, I do agree that it is not road crown. Longer left have an effect, but tire (tyre) pressure is the key.
I also think that compound is a contributor. Like The_Castle, I find the Bridgestones are supremely suited for road use and longer wear...and they seem to be a bit more forgiving.
post #33 of 38 (permalink) Old 02-19-2017, 09:19 AM
Gearhead's Avatar
Send a message via AIM to Gearhead
AH, The__Castle, that is what spirited riding tires should look like! And no chickin "wigs"!
Ed S
Gearhead is offline
post #34 of 38 (permalink) Old 02-19-2017, 10:52 AM
Maximum Velocity's Avatar
Ed S
That is what I was thinking :-)
What a beast of a motorcycle!
Maximum Velocity is offline
post #35 of 38 (permalink) Old 02-22-2017, 09:54 AM Thread Starter
Thanks for all the info/suggestions. I do like a softer compound. In my mind, I feel a bit more secure with a softer tire (tyre). Replacing it often isn't a concern to me. I bought a new Super Corse front only because the rear is in great shape. I think I'll drop a pound or two from the recommended pressure and see how it feels. I'm open to options so once I need the front and rear I'll research different brands.
For those that spell tire, tyre, spell check puts the red squiggly under it. Just sayin'.
2014 F4 RR
2008 Yamaha Raider S
1982 Suzuki GS850L
fingertight is offline
post #36 of 38 (permalink) Old 02-22-2017, 01:58 PM
The_castle's Avatar
I sure don't work for Bridgestone but my tyre of preference, at the moment, is the RS10R.
I must point out that a great tyre will only give its best performance when placed on a bike with well sorted suspension and geometry along with optimum ambient temperature for the compound and they are at the correct pressure. Quality of the road surface / precipitation and friction reducing matter are other variables.
Because there are so many variables that influence tyre performance I would recommend reading up on each of these subjects before focusing too much on any one variable and expecting too significant an improvement.
If I was to recommend an order in which to approach these variables (the ones that you can influence) then I would suggest:
Select your tyre of preference
Tyre pressure
Sorted suspension followed immediately by.....
Sorted geometry
The_castle is offline
post #37 of 38 (permalink) Old 02-27-2017, 04:39 PM Thread Starter
Tyre pressure
Sorted geometry
All good advice. Thank you.
2014 F4 RR
1982 Suzuki GS850L
post #38 of 38 (permalink) Old 04-04-2017, 02:08 PM
Terrys409's Avatar
My front tire did that in only the first few months I owned the TVL. I later realized I was not checking my tire pressure often enough and even got down to the teens. Dangerous! I check it daily now
fingertight and fingertight like this.
Terrys409 is offline
