Potential brake hose issue. <2010 Brutale - MVAgusta.net
post #1 of 2 (permalink) Old 02-08-2017, 03:45 AM Thread Starter
Something to look out for on the rear brake hose. I recently removed the sump on my 07 Brutale to sort out an oil leak and part of the 'work in way' requires the removal of the rear brake master cylinder assembly (it bolts to the sump). On pulling the master cylinder clear of the engine I noticed that the hose from master to slave has been rubbing where it is routed under the engine case. I have attached a couple of pictures showing the result and the approximate place where the wear has taken place. Something for fellow B4 owners to watch out for. I'll be putting some rubber cushioning between the hose and case when I reassemble everything. Just waiting for the header and decat pipes to come back from the beauticians. I decided to get them ceramic coated whils they were off.
Sundodger is offline
post #2 of 2 (permalink) Old 02-08-2017, 06:31 PM
FWIW - F4's and B4's of that era share the same basic rear brake set-up.
