Later model forks - early F4 - MVAgusta.net
post #1 of 9 (permalink) Old 02-05-2017, 12:08 PM Thread Starter
Le Danoir's Avatar
I found some corrosion on my forks where the mudguard collects water against the fork legs so decided to replace my forks.
Found what I thought would be a nice sensitive upgrade with what I thought were later model forks with radial brakes, but the wheel spindle is much smaller on the new forks.
Can I replace the spindle in the wheel or is that not an option?
Le Danoir is offline
post #2 of 9 (permalink) Old 02-05-2017, 08:34 PM
Which model F4 have you got ? There's several threads discussing the two axle sizes on the pre-2010 bikes, as well as the spacers used to accommodate the axle differences.
post #3 of 9 (permalink) Old 02-06-2017, 03:27 AM Thread Starter
Le Danoir's Avatar
Mine's an early 200my 750 with a large spindle.
The later model forks are much smaller so I'm assuming a spindle and wheel bearings will suffice or is there a difference in the wheel?
I searched for 'wheel spindle' so I'll have a look for axle size.
post #4 of 9 (permalink) Old 02-06-2017, 08:53 AM
number2's Avatar
what year bike did the new forks come from
number2 is online now
post #5 of 9 (permalink) Old 02-06-2017, 12:18 PM Thread Starter
Le Danoir's Avatar
Not sure, but the spindle is 25mm
post #6 of 9 (permalink) Old 02-06-2017, 08:35 PM
number2's Avatar
even though it seems simple to just change the bearings you will find the bearings needed for the 25mm spindle have a smaller outside diameter than the older bearings and will not fit the wheel from the older bike. You may have to buy a newer wheel to make it all work. You will also need bigger brake disc
post #7 of 9 (permalink) Old 02-09-2017, 08:41 AM Thread Starter
Le Danoir's Avatar
I'm hoping to be able to source a bearing with the inner radius to match the 25mm spindle and outer radius to match the wheel.
Hopefully these chaps will have something suitable:
Leading Online Provider of Bearings and Power Transmission Components
post #8 of 9 (permalink) Old 02-09-2017, 09:19 AM
No man, all the info you need is in this thread - it's up to you to know your bike, the parts you bought, and to sort through the rest http://www.mvagusta.net/forum/21-per...-they-fit.html
post #9 of 9 (permalink) Old 03-06-2017, 09:54 PM
Le Danoir;
What you need is a pair of spacers part #8000A3470 page C 03 of my Brutale parts manual item #17
they adapt all MV wheels to late forks ...... except the triples
