Seals replacement on F4 Marzocchi front fork - MVAgusta.net
post #1 of 12 (permalink) Old 11-17-2016, 10:22 AM Thread Starter
pires's Avatar
Hello
My F4 has a front fork oil leak, is a 2006 F4 1000R with 50mm Marzocchi.
Anyone know were to find the seals and bushes?
Pires
pires is offline
post #2 of 12 (permalink) Old 11-17-2016, 10:35 AM
APU
Star Twin Trading or you can try aftermarket.
Search this forum for "seal mate". You can also make your own.
APU is offline
post #3 of 12 (permalink) Old 11-17-2016, 12:06 PM
The_castle's Avatar
As it turns out you may just have some road grit between the seal and the fork allowing a small volume of oil to pass the seal on compression.
Have a search for "Seal Mate" on the forum or online.
If that does not sort the leak then, yes - source replacement seals.
Good luck.
The_castle is offline
The Following User Says Thank You to The_castle For This Useful Post:
post #4 of 12 (permalink) Old 11-17-2016, 06:43 PM
A home made 'seal mate' did it for me, just sacrificed part of the plastic cover from one of those floppy binders that hold the sheet protector type sheets. Not the best description I know but hopefully you'll figure out what I meant! Something I would never have thought of except for the forum, saved me some $$$ and down time.
Sundodger is offline
post #5 of 12 (permalink) Old 11-18-2016, 04:30 AM Thread Starter
pires's Avatar
Thanks guys.
I'll try that. Maybe works for me.
I will leave my conclusions at the end.
Pires
pires is offline
post #6 of 12 (permalink) Old 11-18-2016, 06:27 PM
If you do end up having to replace the seals, they're available from forum sponsors, any MV and KTM dealer and eBay, I'll put some part numbers up for you when I get home.
post #7 of 12 (permalink) Old 11-21-2016, 04:19 AM Thread Starter
pires's Avatar
Thanks Donsy
I'll apreciated.
pires is offline
post #8 of 12 (permalink) Old 11-21-2016, 05:01 AM
Originally Posted by pires View Post
Thanks Donsy
I'll apreciated.
Sorry buddy, almost forgot about this.
OK, the seal is a 50x63x11mm size, fairly easy to find on eBay.
Technopolomer AG used to be MV supplier, part # ARI 093.
Come's from www.jmproducta.eu - JM - No. 734.00.93
I've used these guys many times - http://www.pyramidparts.com.au/produ...55-130-ari-093
And these - https://www.af1racing.com/store/Scri...idproduct=2636
http://www.ebay.co.uk/sch/Marzocchi-...2320777/i.html
Good luck
post #9 of 12 (permalink) Old 11-21-2016, 05:33 AM Thread Starter
pires's Avatar
you're the man
Many thanks
Pires
pires is offline
post #10 of 12 (permalink) Old 11-21-2016, 06:38 AM Thread Starter
pires's Avatar
Just one more question.
If i have to replace the seals, must replace bushes and dust seals too?
I'm never done anything like that.
pires is offline
