2012 F4R Brake Calipers on F3 - MVAgusta.net
post #1 of 4 (permalink) Old 10-28-2016, 06:03 AM Thread Starter
PTsalas's Avatar
Hi guys, any idea if the 2012 F4R front Brake calipers (Brembo mono-block) will be an worthwhile improvement over the stock 2012 F3 675 (Brembo non mono-blocks) for occasional track riding (B - group)
How easy a swap will it be other than disconnecting hoses and bleeding brakes afterwards.
Can I take the pads out my F3 calipers and use them (still a lot of meat on them and I dont plan to change the disc)?
PTsalas is offline
post #2 of 4 (permalink) Old 10-28-2016, 06:07 AM
If I recall correctly they'll swap over on the forks dude, but look in pictures to see if the lines will work. The pads won't work.
post #3 of 4 (permalink) Old 10-28-2016, 06:14 AM Thread Starter
PTsalas's Avatar
Looks like the same calipers as on the current model F3s.
PTsalas is offline
post #4 of 4 (permalink) Old 10-28-2016, 04:29 PM
Fork and caliper offset have stayed the same on all models ever since the start of the radial model sales.
You may post new threads
You may post replies
