Brutale 990R rebound damping - MVAgusta.net
post #1 of 6 (permalink) Old 10-13-2016, 03:32 PM Thread Starter
greminn's Avatar
Hi All,
Had a mate of mine, who is a wizz with suspension setup, run thru a basic setup of the 990R. The one problem: there is enough rebound damping in front fork.. we are right at the end of its adjustment.He has suggested new fork oil (and at 30k its prob due), maybe a grade heavier to slow down the oil travel or get the forks adjusted properly.
A couple of questions:
- Am i correct in that they would change the valve stack in the forks, thus allowing more adjustment?
- Does anyone know if the 990R has adjustable shim stack?
- Does anyone know the size of the fork/dust seals?
-- Answered my own question: 50x63x11 (actually anyone know the dust seal size?)
THanks
Simon
Cheers, Simon
Brutale 910R
greminn is offline
post #2 of 6 (permalink) Old 10-15-2016, 03:09 PM
The marzocchi fork is often said to have insufficient rebound damping. Heavier weight oil might get it to where you need it. I don't know if that much can be done to the fork.
Jono is offline
post #3 of 6 (permalink) Old 10-16-2016, 08:50 AM
Give these guys a shout...one way or the other, they can help.
Heavier weight fork oil will slow things down in both directions, but it isn't a substitute for correct valving.
post #4 of 6 (permalink) Old 10-18-2016, 03:26 AM
eddypro's Avatar
You might have a hole or crack in one of the shims ,they are thin and prone to breakage , I changed to andreani cartridge kit ,best thing i ever did .
eddypro is offline
post #5 of 6 (permalink) Old 10-18-2016, 09:12 AM
There was supposed to be a link in there....
Here it is:
http://www.fastbikeindustries.com/
post #6 of 6 (permalink) Old 10-31-2016, 10:35 PM Thread Starter
greminn's Avatar
So went slightly heavier fork oil and that has sorted much of the issue. It's a stop gap measure until I can get it fully done.
Cheers, Simon
Brutale 910R
greminn is offline
