F3 800 Base track suspension setup - MVAgusta.net
post #1 of 7 (permalink) Old 10-11-2016, 10:17 AM Thread Starter
dean100yz's Avatar
Guys, anyone kept the standard stuff in and used their F3 800's on track?
I am quite familiar with suspension but rather than trial and error would like to hear from anyone that has been in the same boat and found a particular setting worked well
The bike will after xmas be having a professional revalve/spring setup for rider weight and style
Its more the comp, rebound and preload front and same rear with track sag
dean100yz is offline
post #2 of 7 (permalink) Old 10-11-2016, 01:18 PM
I have some numbers I will have to take a look when I get home.
FWIW the Sachs shock is pretty limited. I recommend aftermarket. The stock front end works pretty well once you have a good base. IIRC because of the design, it cannot be revalved. You can change the spring though.
JerryJoose is offline
post #3 of 7 (permalink) Old 10-11-2016, 01:41 PM
nk140's Avatar
At expert race pace the front is very limited. The valving is the biggest problem. It seems like there is no compression damping. I got the sag set correctly but I have to keep cranking more preload in to keep from bottoming out the forks.
Todd
2013 F3 675 (RIP)
2014 B3 800 Italia
nk140 is offline
post #4 of 7 (permalink) Old 10-12-2016, 03:08 PM Thread Starter
dean100yz's Avatar
Cheers guys for the replies. I had the bike in the garage tonight getting it ready for Snetterton Friday. Running Bridgestone v02s which are a funny tyre when it comes to sizes... Cut a long story short, yes they fit, and yes they measure at 180 on the back despite the size they quote
Anyways, the suspension is very limited. Essentially comp and rebound max hard turned out 1/4 of a turn. Rear I didn't have time to set sag so I'll do that at track (what's a good base to work on for 14st)
Comp on back max minis 1/2 turn and rebound 1/2 harder from standard
I'm taking wild guesses until I ride it with a friend but it doesn't take much brain power to realise the front is exactly what you two said... Very limited so whatever I do it'll need springs or a better fork setup
Can I ask, do these have pre load? I turned it on two full turns and could hear the washer turning on the spring but it's not like my gsxr there are no rings that drop as you bring it on making me think there is actually no adjustment. That maybe a stupid question so apologies if so and please don't shoot me down in flames
Sent from my LT30p using Tapatalk
post #5 of 7 (permalink) Old 10-13-2016, 03:29 PM
Did I miss something? I'm sure you naffed off and bought an Aprilia or something?
Yes the preload is adjustable. Had to slacken mine way way off from stock settings to get 25mm of rider sag. Feels nice now though. And the fork doesn't have much rebound damping.
Jono is offline
post #6 of 7 (permalink) Old 10-15-2016, 04:20 AM Thread Starter
dean100yz's Avatar
Haha I have an Aprilia on the road for the next 18 months until they bring out a Dragster 1000
For track I have an F3 800 that Im able to ride a fair bit
And I can say after being on it yesterday at Snetterton...wow wow wow I forget how good those triples sound. Its got my QD pipe on off my Dragster RR and the sound!
Its a good 10-15% quicker on the my GSXR750 track bike which makes 121 at the rear and runs -1+2 gearing. The MV was completely stock barring V02's and the QD
Suspension was OK at best. There is no pre load adjustment on the front and essentially we just had the comps just off max front and rear with a touch more rebound
It was tearing the rear from a bad setup but I still ran 2.07/8's so its got alot of potential
TC was 2 and never came on
QS lever had to be lowered, after this the changes felt real quick and slick
ABS off - I didnt bother trying race mode. You are better people than me if you can lock a front on track with slicks
I didnt get any video but will be in Spain doing Almeria and Andalucia in 3 weeks so will be getting a few videos hopefully showing all the dash working away
post #7 of 7 (permalink) Old 10-17-2016, 11:57 AM
Really? I'm shocked. The Brut has preload adjustment so why not the F3? C'mon MV....
Circuit de Almeria at Tabernas? I live near there. Sometimes. You'll prob be able to race Tito Rabat. He darned near lives at the track.
Jono is offline
