Stainless steel brake lines for F3 675 (13) - MVAgusta.net
post #1 of 8 (permalink) Old 10-07-2016, 10:49 AM Thread Starter
I'm looking to upgrade my brake lines to stainless steel and was curious if anyone could point me in the right direction of a good company to do this.
I did find one company based in Europe (I live in the US) called Goodridge but didn't want to order without some input.
https://goodridge-uk.myshopify.com/p...675-augusta-13
Thank you!
bryanf3 is offline
post #2 of 8 (permalink) Old 10-07-2016, 02:07 PM
Goodridge have a very good rep in the U.K. My MV dealer talked about issues bleeding the abs pump - so bear that in mind.
In fact, my MV is my only bike to not have braided lines, and because doing it looks "non trivial". And the brakes are plenty good enough, so far, for me.
manicguitarist is offline
post #3 of 8 (permalink) Old 10-07-2016, 08:55 PM
jimboF4's Avatar
Standard fitting
All the modern MV bikes have braided brake lines as standard.
jimboF4
jimboF4 is offline
The Following User Says Thank You to jimboF4 For This Useful Post:
post #4 of 8 (permalink) Old 10-07-2016, 11:23 PM
The F3's don't have them, at least mine doesn't and its a 2015.
I was also looking at lines but I'm not sure they've made for ones with ABS yet.
http://www.carpimoto.com/en-AE/Bike_...sta-F3-675.htm
116618LN is offline
post #5 of 8 (permalink) Old 10-08-2016, 12:09 AM
Ok, I'm sure your lines might not look like the Goodrich lines, but I'm sure they're at the very least steel braided lines with a plastic coating if not stainless mate. So if you're looking for improved braking performance then you're going to be dissapointed.
post #6 of 8 (permalink) Old 10-08-2016, 09:39 AM
Yep. They're covered but s/s underneath. I think the stock brakes are way more than good enough.
Then again I used to have a Harley so what do I know?
Jono is offline
post #7 of 8 (permalink) Old 10-08-2016, 12:26 PM
Well I never!
They are indeed braided with a covering on! I just assumed rubber without looking.
post #8 of 8 (permalink) Old 10-09-2016, 09:32 AM
This is a quality vehicle with a high specification as standard.
Jono is offline
