Had my bike professionally setup - MVAgusta.net
post #1 of 17 (permalink) Old 09-17-2016, 10:56 AM Thread Starter
By TW suspension in Preston.
Best £40 I've spent on a bike. I thought my setup was good already. He's turned my butter knife into a scalpel. Ride in/out service.
If you're in the North West of England I can recommend without reservation.
manicguitarist is offline
post #2 of 17 (permalink) Old 09-17-2016, 04:03 PM
jimboF4's Avatar
It would be useful to other owners if you could share what was done to your bike? I assume it was a case of setting up the standard components rather than fitting different units?
jimboF4
jimboF4 is offline
post #3 of 17 (permalink) Old 09-17-2016, 04:25 PM Thread Starter
Yes, standard kit - however I'm not sure that suspension settings are transferable between people - as weight and position on bike where all measured.
I will check out what settings mine are on tomorrow and post here - however, the fact that mine has been lowered and the forks dropped through the yoke also will change things.
post #4 of 17 (permalink) Old 09-18-2016, 08:16 AM Thread Starter
Bear in mind that my bike has been lowered by a suspension linkage.
All units are in 180degree turns
Front:
Compression out: 4
Rebound out: 3 1/2
Preload (in) Left fork 15, right fork 15 1/4
21mm of fork showing above the yoke - measured at where the clamp has its join
Rear:
Compression out (top) 3 1/4
Rebound out 4 1/2
Preload 31mm
post #5 of 17 (permalink) Old 09-18-2016, 05:18 PM
21mm drop? Wow. What do you weigh? Sorry to be personal.
Jono is offline
post #6 of 17 (permalink) Old 09-18-2016, 05:44 PM Thread Starter
Don't forget rear dropped too. #ShortAss
post #7 of 17 (permalink) Old 09-18-2016, 08:53 PM
What does that have to do with rider weight?
Rider weight is compensated for by spring rate and preload...not how much the fork tube is protruding from the yoke.
post #8 of 17 (permalink) Old 09-19-2016, 02:38 AM Thread Starter
Non at all, I was just giving all the details on my setup.
post #9 of 17 (permalink) Old 09-19-2016, 03:09 AM Thread Starter
13st in my kit.
post #10 of 17 (permalink) Old 09-19-2016, 04:25 AM
jimboF4's Avatar
Manic,
Thanks for sharing your set up very interesting, can i ask did you specifically ask for the bike to be lowered? Front fork pulled up by that amount is a fair amount, how is clearance on front mudguard when hard-on the brakes, also has the leading edge of the fairing grounded?
All good info for owners, and gives others some ideas, not being cheeky but a rough idea of inside leg measurements and you height will be useful as well, and yes I am a short arse before you ask.
jimboF4
jimboF4 is offline
