Spring sources
Im browsing around for some stiffer springs and wonder where people are getting their front and rear springs. I am about 190lbs with gear but i usually ride with a back pack so +5lbs maybe and just trying to get the front tuned in and it seems like there is just too much travel/sag. Its sitting at 25mm range when i sit on the bike. (havent measured the upper full range). Thanks! 2008 910s
Sponsored Links | |||
Advertisement |
Try these guys: http://www.fastbikeindustries.com/
Öhlins series # 1091 are a direct replacement for rear shock springs
you can use series #1093 but you must change the spring cap for a taller one
Advertisement |
any reccomendations for what spring rating to upgrade to?
Originally Posted by Peteroo
View Post
View Post
If you go through this section, you'll find threads started by Glenn - ( http://www.mvagusta.net/forum/member.php?u=9614 ) - about hyperpro spring replacements.
http://racetech.com/ProductSearch/2/...Tricolore/2013
http://racetech.com/ProductSearch/2/...Tricolore/2012
Click on "Calculate Spring rates..."
do the 12-13 tricolore have the same spring rates and the 08 brutale?
View Post
front spring rate depends on the front axle load....
fork brand doesn't count ..... it's Hook's Law, look it up
RaceTech's spring calculator works, use it
I like spring rates and damping way different than most people.....
light springs with lots of preload and very little damping
my '08 Brutale has 1.0 Kg/mm springs and it's bad on bumps..
my Aprilia RSVR has 0.85 Kg/mm springs and its a delight to ride(0.85 is the lightest
spring RaceTech has for the Showas) I'll never sell that bike.... it's so confidence
inspiring that it was going to kill me
on the rear, me giving you the spring rate.....is meaningless, because you're working
with the square of the linkage ratio
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
