Brembo Brakes - MVAgusta.net
post #1 of 3 (permalink) Old 09-01-2016, 05:03 AM Thread Starter
Bruce Taylor's Avatar
Brembo Brakes
Brake master cylinder damaged when the lever was in contact with a car turning right in front of me.
Two options
1) Replace with the MV assembly
2) Fit a Brembo Master cylinder assembly and matching clutch lever.
Can any one confirm that Brembo master cylinder is compatible with the ABS system
Bruce Taylor is offline
post #2 of 3 (permalink) Old 09-01-2016, 05:07 AM
The ABS system is driven by the pump unit and wheel speed sensors. The master cylinder is simply a hydraulic pressure pump.
As long as the pump supplies the proper pressure the ABS unit won't know what brand is doing the job.
In other words, yes...if sized correctly.
post #3 of 3 (permalink) Old 09-03-2016, 07:01 AM
dansoarr's Avatar
Cant see why the Brembo wont work, my bike (F4 ABS) runs a Galespeed VRC equivalent of the Brembo RCS on the clutch and brake. Only issue you should have is whether to to change the brake lines or use an adaptor to the radial mount.
If you want to borrow my standard brake while you wait for what ever you buy feel free your not too far from me (PM me)
cheers
Arron
2015 MV F4, ABS
ECU Mapped with ECUstudio
others
GSXR 1000
GSXR 750
dansoarr is online now
