Page 1 of 2 | 1 | 2 |
ABS brakes
Have a 2013 MV F4 RR and the ABS on/off option does not appear on the Dash menu as the user manual states?
Sponsored Links | |||
Advertisement |
Hi, i guess the first question is do you ABS fitted as not all did? If you are not sure then remove the pillion seat. If you have a small space for storing the tool kit you dont have ABS. If the is a big ABS pump then you do.
My dash shows abs options race on or off.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
Or see if you have the ABS ring on the hubs?
Advertisement |
OK thanks for your replies, it has the speed senor rings on the hubs, ABS light on the Dash but no unit under the pillion seat.....
Unfortunately then it does not have ABS, the wheel 'ABS' rings are also used for speedo on my bike.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
abs can put yourself if you have a service tool.
Ildar, is that just a flash of the dash or the ECU as well?
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
you will need to activate the ABS module.
if you want to install abs module. 1. you need to own the ABC module. 2. make the brake hoses. 3. Those switches are replaced on wheels. 4. Those switches connect the module and both the wiring diagram
Here`s a diagram of parts for ABS. The ABS Module is $2200 by itself.
http://shop.startwintrading.com/en/p...king-system-24
2014 MV Agusta F4
Moto Guzzi 1100 Sporti
Yamaha R1
Honda CT90
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
