Steering Damper
Hi All
Dose any know of an upgrade to the original steering damper as my one dose not make any difference hard or soft and I get a lot of head shake on acceleration.
I would like to keep the same fixing and setup as standard but just change the damper.
Craig
Craig
Sponsored Links | |||
Advertisement |
Originally Posted by craigzx9
View Post
Hi All
Craig
Craig
I had a lot of headshake when I got the bike, and the damper was not effective at all!
After I set up the dampers on the bike properly, the headshake is gone, and the steeringdamper is doing its job.
15' Dragster RR
97' Triumph Speed Triple T509
08' Alfa Romeo 159 Q4
94' Lancia Delta Integrale EVOII Bianco Perlato
92' Lancia Delta Integrale EVOI 8v
Hi
What did you do to set up the damper was this the stock one ???
Advertisement |
He is talking about setting your front and rear suspension correctly. Look up setting static/dynamic sag if you want to try it yourself, or take it to a suspension specialist, they will be able to set it for your weight, or recommend harder/softer springs if needed.
And then get the damper serviced.
Hi I have had all the suspension set up by FTR and the bike handles a dream, but still gets a head shake on aggressive acceleration.
On my bike if you turn the dial from hard to soft it make no difference to the steering resistance.
Is the standard CRS unit serviceable ?
Following. I get the same problem and have had the suspension adjusted.
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
