Brutale 800 compression side fork weeping oil - MVAgusta.net
post #1 of 8 (permalink) Old 06-06-2016, 07:37 PM Thread Starter
Haven't really played much with my fork adjustments on my 2014 B800. But gave it a quarter turn "softer" on the weekend.
About an hour into my ride noticed a bit of oil collecting on the top fork nut. Don't think it's coming from the upper seal but hard to tell where, and it's not pouring out or anything.
Could it be coming from the adjuster?
Farmer is offline
post #2 of 8 (permalink) Old 06-06-2016, 09:27 PM
Yes it could mate, it's just an O-ring used for sealing. I'd carefully wind the adjuster all the way in while counting the "clicks", and then back out to where you had it, the O-ring might just need a little movement to help it seat and seal properly again.
post #3 of 8 (permalink) Old 06-07-2016, 06:04 PM Thread Starter
Thanks, Donsy.
No clicks with the adjuster, as it's just a screw in and out affair. So wound it all in, slowly, and all out, slowly, then back to where it was approximately.
Will report back!
Farmer is offline
post #4 of 8 (permalink) Old 06-07-2016, 07:05 PM
No worries mate, when there's no "clicker", count the turns ok.
post #5 of 8 (permalink) Old 06-09-2016, 07:03 PM Thread Starter
Thanks for the advice, think it worked!
Farmer is offline
post #6 of 8 (permalink) Old 06-09-2016, 07:30 PM
Cool, crossed fingers.
post #7 of 8 (permalink) Old 06-18-2016, 10:33 PM
found mine leaking yesterday as well . . I've turned the screw all way in and 1 turn out to see if it still leaks.
Need rain to stop before I can check though
'14 Brutale 800
hallmar is offline
post #8 of 8 (permalink) Old 07-28-2016, 12:03 AM
I have been waiting on the oem o-ring to fix my problem, but ended up replacing the o-ring with a BS-006 and that has fixed my leak.
When I took off the old o-ring it wasnt very stretchy and broke, so I had a fair idea that was the problem
'14 Brutale 800
hallmar is offline
The Following User Says Thank You to hallmar For This Useful Post:
