2014 F4RR Ohlins settings - MVAgusta.net
post #1 of 4 (permalink) Old 05-09-2016, 04:53 PM Thread Starter
Hey Guys,
I know that I have to set the suspension from the dash. The owners manual says you can only do it when it is in "custom" map. The problem is, there is nothing I can find in the menu for custom mapping anything. It talks about setting the throttle response, engine braking, etc. in the "map" but I can't seem to figure out how to access it. The only thing I can set manually in the Ohlins settings is the steering damper. Anyone know what I'm missing here?
2014 F4 RR
2008 Yamaha Raider S
1982 Suzuki GS850L
fingertight is offline
post #2 of 4 (permalink) Old 05-10-2016, 02:26 AM
Fragile's Avatar
Procedure is cryptic when reading manual at first but it can be done. Custom map is when you toggle to the setting "C" on upper right quadrant of display. This is all off my memory so check manual for how to get it to that map. Typing on phone here, excuse typos, but i know that you can toggle to that map "C" when bike is running as well. Then all settings can be adjusted. Read manual
'15 Panigale R (2K miles)
'15 Fireblade SP (1K miles)
Los Angeles North
Fragile is offline
post #3 of 4 (permalink) Old 05-10-2016, 02:50 AM
Fragile's Avatar
4.4.7. How to select the mapping of the control unit
In the F4 R and RR models you may select a special
mapping of the control unit, which will enable you to
achieve higher power and efficiency for a briskly dri-
ving experience.
The mapping of the control unit can be selected by
pressing the start button when the engine is switched
on. “SPORT” appears on the dashboard display to
show the mapping has been selected.
WARNING
The mapping selection may be changed or
set when the engine is on, the gear in neu-
tral, the motorbike stationary with your feet
on the ground. Do not change the dis
Los Angeles North
Fragile is offline
post #4 of 4 (permalink) Old 05-10-2016, 04:20 PM Thread Starter
Thanks guys. I had read that before but just couldn't find it in the manual. Instantly remembered when you posted it and I even remember telling someone else in a previous thread. I'm getting old.
2014 F4 RR
1982 Suzuki GS850L
