Another Tyre Pressure Question...... - MVAgusta.net
post #1 of 22 (permalink) Old 05-06-2016, 04:03 PM Thread Starter
Calcifur's Avatar
Sorry guys, I know this has probably been done to death by now, but I can't find the info I'm looking for.
I have a Brutale 750 and it has set of Maxxis Supermaxx Sports fitted at the moment. I checked the pressures today and they are 32psi Front and 38psi rear. The manual says I should have 33 front and rear. I understand that manufactures have their own specs for tyres but I can't seem to find the specs for Maxxis. is 32/38 OK?
I am new to riding so forgive my ignorance, but I am not really sure how running higher psi affects the grip/handling compared to what the manual says.
Calcifur is offline
post #2 of 22 (permalink) Old 05-06-2016, 05:07 PM
Usually, a tire manufacturere will default to the bike manufacturer specs. This is also true of car and truck tires.
I would run 33/33.
post #3 of 22 (permalink) Old 05-06-2016, 09:28 PM
Midnicrow's Avatar
I run 33/33, but it seems the pressure goes up to 35-37 when they are hot. Its normal I guess, taking into account heat and air expansion and what not... So after 5 mins of ridding you are not really at 33 but a higher PSI.
James M.
Midnicrow is offline
post #4 of 22 (permalink) Old 05-07-2016, 04:23 AM Thread Starter
Calcifur's Avatar
Mine were cold when I took the reading so I wonder what they reach when hot... I'll maybe drop the to 33/33 and see how goes. I guess I can away pump them up if I don't like it!
2004 Matt Black/Grey Brutale 750s
Calcifur is offline
post #5 of 22 (permalink) Old 05-07-2016, 08:37 AM
Unless you are racing, or doing a track day, your tire pressure should always be measured cold.
post #6 of 22 (permalink) Old 05-07-2016, 09:07 AM
Maximum Velocity's Avatar
Is it right that 33 psi is about 2.2 bar? Seems low to me. I run a bit more.
What a beast of a motorcycle!
Maximum Velocity is offline
post #7 of 22 (permalink) Old 05-07-2016, 09:10 AM
33 psig = 2.27527 bar
post #8 of 22 (permalink) Old 05-07-2016, 01:25 PM
33 is what it says on the sticker on the fork. And in the book.
Jono is offline
post #9 of 22 (permalink) Old 05-10-2016, 03:08 AM
emmevi125s's Avatar
The sticker is only an indication and probably related to the OEM tyres not the tyres you replace them with. Tyre pressure for a road bike is measured cold. The best source for the tyre pressure is the tyre manufacturer and should take into account your weight (including luggage and pillion where applicable) and the ambient air temperature (tyre pressure will be different on a sunny 30+ day to a wet 10 day). The rear tyre is usually a higher pressure than the front for road use but the opposite for track days. The tyre pressure is determined, in part, to provide 'strength' to the side wall which in turn effects the tyre contact patch/handling/temperature. For most riders having a 'fun' ride around a favorite twisty (in other words there are chicken strips on the rear tyre) a variation in tyre pressure by 1 psi will not be noticeable or have any detrimental effect on the handling (suspension and relaxed riding is more important).
emmevi125s is offline
post #10 of 22 (permalink) Old 05-10-2016, 03:33 AM Thread Starter
Calcifur's Avatar
Thanks for the responses guys. I set the pressure to 33/33 and went for a 200mile run with some friends to Aviemore and back. The temp was 20+ and there was some spirited riding involved and the bike felt fine. I am running the maxxis supermax sports that were on the bike when I bought it. I looked for maxxis specs but can't seem to find them. But all seems well for the moment.
Thanks again
Calcifur is offline
