Quick Quick Brake Bleeding Question - MVAgusta.net
post #1 of 4 (permalink) Old 05-01-2016, 02:15 PM Thread Starter
PTsalas's Avatar
Hi Guys,
I need to bleed my front brakes and bought a mityvac 800 kit to do it.
It looks pretty simple, I just want to clarify before I put spanner on the bike as the manual is a little ambiguous.
When Ive got the vac's hose attached to the bleed nipple, do I loosen the top piece of the bleed nipple or do I loosen the bottom (12mm I think) where the white factory paint is resting on the copper washer. I think its the bottom piece but just really want to make sure before I strip something.
PTsalas is offline
post #2 of 4 (permalink) Old 05-01-2016, 02:40 PM
jimboF4's Avatar
Do not lossen he lower fitting, after attaching the hose, build up vacuum in the mityvac and then lossen the upper 8mm nipple by no more than half a turn. After a few pumps on the vacuum close the 8mm nipple and check fluid level in master cylinder.
Repeat a few times, then switch to other caliperand repeat, use only fresh new dot 4 fluid until you have a firm lever pressure. If your not confident leave it alone.
jimboF4
jimboF4 is offline
post #3 of 4 (permalink) Old 05-01-2016, 05:50 PM Thread Starter
PTsalas's Avatar
Top 8mm it is, thanks!
Good thing I asked, my first instinct was the 12mm lower
PTsalas is offline
post #4 of 4 (permalink) Old 05-02-2016, 04:39 AM
That's where the manuals come in mighty handy.....
