stock suspension 2015 f3 800 - MVAgusta.net
post #1 of 31 (permalink) Old 04-23-2016, 11:14 PM Thread Starter
caloots's Avatar
finally took it out today..
what I noticed.
the mirrors are for amusement purposes.
the drive by wire is extremely sensitive .
the suspension "seems" very stiff.. or was it bottoming out in the front ?
i think just stiff..
is there room to work with the stock forks?
any suggestions on adjustments ?
im 5.9. about 190+ when you add in the leathers.
otherwise.. it feels awesome.. very nimble.. cant wait till the breakin period
is done.!!
caloots is offline
post #2 of 31 (permalink) Old 04-24-2016, 12:43 AM
That breaking in is just to get you used to the bike.
post #3 of 31 (permalink) Old 04-24-2016, 08:57 AM
Welcome, I am near the Mass border in NH as an FYI -
My mirrors came off pretty quickly after riding the bike a few times after seeing nothing but my elbows.
I'm a bit heavier than you but I do think the front end bottoms out on stock settings, there is a nice suspension thread in here with some good input ( http://www.mvagusta.net/forum/showthread.php?t=165953 )
2014 Brutale 800
eas, non-abs
wt800 is offline
post #4 of 31 (permalink) Old 04-24-2016, 09:08 AM Thread Starter
caloots's Avatar
Thanks guys.. awesome wt800.. I'm on the Nashua border. 😁.. thanks for the link
caloots is offline
post #5 of 31 (permalink) Old 04-24-2016, 08:48 PM Thread Starter
caloots's Avatar
ahhhh i was hoping I could work with the factory suspension.. I cant afford a 1500 suspension upgrade..
caloots is offline
post #6 of 31 (permalink) Old 04-25-2016, 07:33 AM
Give these guys a shout... http://www.fastbikeindustries.com/
post #7 of 31 (permalink) Old 04-25-2016, 09:19 AM Thread Starter
caloots's Avatar
Awesome.. I'll take a look
caloots is offline
post #8 of 31 (permalink) Old 04-25-2016, 03:10 PM
If you find the ride by wire too sensitive, go into custom settings and put throttle sensitivity to normal mode. Leave everything else sport mode.
dazo is offline
post #9 of 31 (permalink) Old 04-25-2016, 05:16 PM
cus
cus's Avatar
put a zip/cable tie around one of your fork legs up near the dust seal and go for a good ride then check where on the leg the tie is sitting compared to the extended fork length and you will know how much travel you are using. You have to set the sag at both ends to suit your weight and get such base measurements before wasting money on suspension upgrades.
cus is offline
post #10 of 31 (permalink) Old 04-25-2016, 08:26 PM Thread Starter
caloots's Avatar
thanks !!! good to know~!
caloots is offline
