Recommendations - MVAgusta.net
 3Likes
post #1 of 22 (permalink) Old 07-30-2019, 02:25 PM Thread Starter
Recommendations
Just got a new to me 2015 dragster rr. It came outfitted with all the rizoma stuff and carbon fiber as well as the fm slip on exhaust. Looking for recommendations on things to look out for, and important upgrades. Two first things on my list would be ecu flash, and I would love a recommendation on a stand. Thanks everyone!
Dangydave is online now
post #2 of 22 (permalink) Old 07-30-2019, 02:30 PM
dansoarr's Avatar
hi welcome to the family.
ECU Flash, I'd recommend ECU Studio ECU Studio
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #3 of 22 (permalink) Old 07-30-2019, 02:35 PM Thread Starter
Thanks!
post #4 of 22 (permalink) Old 07-30-2019, 07:12 PM Thread Starter
Another random question, I circled the radiator trim in the attached photo, they are quite easy to move around. Is this normal?
New owner here so apologizes if I'm being a tad neurotic.
post #5 of 22 (permalink) Old 07-31-2019, 04:30 AM
iirc, there are 3 fixing points. One behind indicator, seen in photo. The other 2 are on one bracket behind wheel on outer part of rad.
Past experience has taught me that the 2 bolts on the rad give it it's stiffness.
In saying that it definitely does flex a bit. But just check to see that you have all the bolts.
Also, super high priority!!! Get a rad guard, you will not regret it one bit
Brutale800RR likes this.
Kag
Kageira is offline
post #6 of 22 (permalink) Old 07-31-2019, 05:25 AM Thread Starter
Thanks for the tip!
post #7 of 22 (permalink) Old 07-31-2019, 06:46 AM
lucydad's Avatar
Agree, get a radiator guard.... one of the best upgrades for these bikes especially if you ride chip-sealed gravel type roads.
Pitbull makes some great quality rear stands, that is what I have for my 2018 Dragster RR.
Enjoy!
Never ride faster than your guardian angel can fly....
2018 MV Agusta 800 Brutale RR-- "Betttina" in Giallo-Nero
lucydad is offline
post #8 of 22 (permalink) Old 07-31-2019, 09:17 AM
CharLy's Avatar
take those rear pegs off
not a fan of crash bungs but i guess that's a personal thing
only thing that fell off mine in 12k (miles) is the chain guard as only held on by tiny screw
the hoses going between the forks can rub & wear to so give them a check over to
just enjoy!
“If you don't know where you are going any road can take you there”
CharLy is offline
post #9 of 22 (permalink) Old 07-31-2019, 01:16 PM
Check the sprag clutch. If you have issue starting and it ends with a loud clack that’s it.
Check the rear hub/entire stack for any side to side motion. If it’s moving something might be up.
Check the tank to ensure it isn’t swelling. Easiest way to tell is look at the steering damper from the gas tank fuel door and look at the ends of the steering damper. If one is closer to the tank = swelling.
Check the connector that holds the clutch cable to the radiator. It’s a weak piece of plastic that will snap at some point.
Outside of that ride the piss out of it. She likes it that way.
Atom
Brutale Dragster RR
Atom is offline
post #10 of 22 (permalink) Old 08-01-2019, 06:06 AM Thread Starter
This is what happens when I get a new bike, I start thinking everything is a problem on it! Now I cant stop looking at the gas tank mainly because the previous owner left gas in it for awhile.
