Led flasher relay, Rizoma, R&G - MVAgusta.net
post #1 of 3 (permalink) Old 07-22-2019, 09:13 PM Thread Starter
Hi, Has anybody had any luck using the Rizoma, R&G, or any of the other led flasher relays to get proper flash rate without the resistors on a 17+ b3? Is it even a issue, I've seen one person run the rizoma vision with no prob but it's a 3.4 watt led. Most or the others are 1-2 watts. Would like to not have to tuck those resistors up into my R&G tidy on a 19 RC.
Rob G is offline
post #2 of 3 (permalink) Old 07-22-2019, 10:34 PM
cherche's Avatar
Have a look here:
https://www.mvagusta.net/forum/53-br...gnal-help.html
2018 Brutale 800RR
cherche is online now
post #3 of 3 (permalink) Old 07-29-2019, 04:17 PM Thread Starter
Thanks for the link, looks like it all just depends on the wattage of the indicator. I'm installing the rizoma zero that I had on my previous 2015 b3 rr. On that bike I only needed resistors on the rear for them all to work properly. Just tried that on the new 2019 and still had fast flash. With the zero on 2017 and later it takes resistors all around for proper flash rate. There's really nowhere good to put the resistors on the later bike on the front so either going to try the solid state flasher with the zeros or just pick up some rizoma vision that apparently does not need the resistors as they consume 3.4 watts vs about 1 watt on the zero. To sum it up looks like indicators that have multiple LEDs within will have a better chance of working with less resistors, and the earlier b3s are if fact different then the later. Does anyone know if these later bikes are canbus because they have some much smaller resistors if so for this application. And has anyone replaced the flasher/intermitance relay on 17+ with any luck?.
Rob G is offline
