Dragster RR Euro4 Tank Ring Specs - MVAgusta.net
 5Likes
  • 2 Post By Black_Gold_Saw
  • 1 Post By lucydad
post #1 of 10 (permalink) Old 05-16-2019, 10:13 AM Thread Starter
Hi
Using the attached, could somebody tell me what the Tank Ring Spec is please?
I can tell its the top right diagram, anyone know what the screw size is? Would be a bonus if you knew the distances too!
Failing that, I can measure the next time im with the bike.
Kag
Kag
Kageira is offline
post #2 of 10 (permalink) Old 05-20-2019, 08:10 AM Thread Starter
I have ordered the ring I believe will fit and just had it delivered today.
I will update this thread with the outcome
Edit: Had to delete a rogue comma; was bugging me!
Kag
Kageira is offline
post #3 of 10 (permalink) Old 05-20-2019, 08:32 AM
Black_Gold_Saw's Avatar
Havent seen this thread pass by. Which kit did you ordered?
Mv agusta motorcycle use 6 screws and thus needs to be a "Quick Lock Evo tankring Triumph" kit.
If you ordered the Triumph daytona 675 kit you should be fine.
(You'll probably need to shave off a tiny bit of material on the first right sided screw on the inside of the lower tankring. Fuel cap is rubbing against it)
lucydad and Kageira like this.
"Mileena"
Black_Gold_Saw is offline
post #4 of 10 (permalink) Old 05-20-2019, 10:54 AM Thread Starter
I did order the Triumph one. The exact name escapes me atm. I will check when I get home. Thanks for the reply
Kag
Kageira is offline
post #5 of 10 (permalink) Old 05-20-2019, 12:40 PM
lucydad's Avatar
Saw of Black Gold is exactly correct. I transferred the EVO tank ring from my Triumph 675 STRX directly to my 2018 Dragster RR. Do be careful as the screw lengths do vary. And I did have to shave a bit off the tank ring. Works perfect, and a very fine addition to the bike. I have the "mini" bag.
Kageira likes this.
Never ride faster than your guardian angel can fly....
2018 MV Agusta 800 Brutale RR-- "Betttina" in Giallo-Nero
lucydad is offline
post #6 of 10 (permalink) Old 05-21-2019, 05:37 AM Thread Starter
Can confirm; the triumph ring fits the Euro4 dragster.
I ordered an evo tank bag and the Triumph TRT.00.640.16000/B tank ring (https://www.sw-motech-shop.co.uk/EVO...crews.-Triumph.)
I used a combination of some of the bolts provided and the original bolts from the fuel cap on the bike. Apologies as I didn't document which ones.
As said above, you may need to shave the end of the ring on the inner, bottom right area. Fit it all by hand, open the fuel cap and you will see what we mean.
And lastly, the tank bag is really, really good. I got the daypack bag. It's main purpose is to alleviate the weight and space from my backpack, which is does perfectly. All the small heavy stuff is put in there and is now a fixed weight on my bike. I cant tuck in as much as I used to when riding but I will get used to it.
Good luck forum searcher!
Kag
Kageira is offline
post #7 of 10 (permalink) Old 05-21-2019, 06:46 AM
I use the daypack aswell, large enough to fit some basic items.
Small enough to not be in the way while riding.
My fat belly doesnt allow propper tucking anyways....WIN WIN situation.. or is it LOSS LOSS situation..
esq'z me and Kageira like this.
"Mileena"
post #8 of 10 (permalink) Old 05-21-2019, 07:27 AM Thread Starter
At the very least, it hides the stomach!
Kag
Kageira is offline
post #9 of 10 (permalink) Old 05-21-2019, 12:17 PM
XPARAUK's Avatar
Well, at least until you get off the bike
XPARAUK is offline
post #10 of 10 (permalink) Old 05-23-2019, 09:26 AM
makers_mike's Avatar
This is the one I ordered for my 2019 Euro4 Dragster:
https://www.revzilla.com/motorcycle/...agusta-triumph
Just thought a link might be able to help others out.
-Michael
2019 MV Agusta Dragster RR
2017 Aprilia RSV4-RF (SOLD)
2016 Aprilia Tuono Factory (DECEASED)
2015 MV Agusta Dragster RR (SOLD)
2013 Triumph Daytona (SOLD)
makers_mike is offline
The Following User Says Thank You to makers_mike For This Useful Post:
