initial Running in, of new engine - MVAgusta.net
 99Likes
post #1 of 93 (permalink) Old 05-06-2019, 05:56 AM Thread Starter
SAROY's Avatar
How are you guys running in your new 800cc engines, whether dragster, brutale, F3
you slowly build up the revs as miles go on?, and how did you get on with the 500 mile service
Does anyone in UK have a set of RG3 exhausts for a 2006 F4 1000R (for sale).
SAROY is offline
post #2 of 93 (permalink) Old 05-06-2019, 06:59 AM
Wow, this is the first time that question has been asked....
Probably right behind "Which Tyres...." or "Which oil...."
The answer to this question is highly subjective. My personal opinion is to simply ride the bike like you will ride the bike. The engine has been to redline on a dyno for testing and it really doesn't care what you do to it. Some say varying engine speed and not droning at a constant RPM helps seat things and wear them in evenly.
Allworld likes this.
post #3 of 93 (permalink) Old 05-06-2019, 07:17 AM
I know I am a bit odd, but I actually follow the recommended break-in process...at least for the most part. Occasional full power blasts don't hurt anything, as long as the engine is thoroughly warmed up.
Warm the engine before riding....or even revving the engine. Just let it idle after start until the temp comes off "cold".
Vary load on the engine, which means most normal riding. Freeway droning requires modulated throttle/rpm with occasional acceleration and coasting.
Don't run extended periods of high rpms/loads.
Mostly, break-in is to give transmission components, plain bearing surfaces (cams and crank), and other moving parts time to get to know each other and mate their surfaces smoothly.
Not to mention brake and suspension parts.....and YOU. You need to become familiar with your new bike.
post #4 of 93 (permalink) Old 05-06-2019, 07:28 AM
Black_Gold_Saw's Avatar
Im definitely not an expert. Nor do I know what to do to get the best cylinder seal. All I can tell you is my experience and that my bike doesnt burn oil.
*Im at 2500 total miles now*
So, I bought Mileena brand new with an rev limiter at 8500rpm. (european A2 license bs)
The way I rode it, is loading the engine as in semi-hard accelerating (not pinning it) not bumping it onto the revs limiter changing normally up the gears and let the bike roll out on its engine braking
Over and over again for first service interval(600 miles).
From 600 to 2000 miles similar riding. Load the engine every now and then and used engine braking. (Go to custom mode and set engine braking to normal mode. That way the engine brakes harder on its own than in sport mode)
from 2000 to 2500 I got access to full power (15.500 rpm) and I build it up from 8.000 to 10.000 rpm. 10.000 to 12.000 and 12.000 to 15.000.
I didnt follow the manual as it says how to increase more RPM the more miles you ride.
I just loaded up the engine from the get go but never went into top gear and pinning it to the rev limiter.
SAROY likes this.
"Mileena"
Black_Gold_Saw is offline
post #5 of 93 (permalink) Old 05-06-2019, 07:40 AM
Rob Caso's Avatar
I'm with @Black_Gold_Saw on this one.
Above all, be smooth - no jerky on or off throttle. No long periods of idling. When the engine is fully warm, take it from low RPM up to maybe 3/4 of redline in a single gear and then off throttle all the way back down w/o a down shift. A long off throttle while in gear pulls oil up around the rings which cools and lubes any hot spots. Then ride a little (smoothly) and do again. As the miles accumulate, keep pushing the RPM. This is Kevin Cameron's advice BTW and I have had good results following it. With CAD designed and CAM produced parts these days, the tolerances and therefore the engines are so much better that, according to Mike Duzik a Ducati expert, they break in almost instantaneously. They're unlike the old bikes (except BMW) which were built using yardsticks.
SAROY likes this.
RC
Failure is not an option
2016 Tri Thruxton R
2005 Ago F4 1000
2005 BMW 1200GS
1995 Duc 916
1994 Bim DB2
1986 Duc MHR Mille
1983 BMW R100S
1975 Hon 400
1975 BMW R90S
1974 Duc 750 Sport
1972 Hon 750
1966 Hon S90
1965 Duc Monza
1971 Norton 750
1971 BMW R75
Rob Caso is offline
post #6 of 93 (permalink) Old 05-06-2019, 07:46 AM
Break-in (running-in) is not just about pistons, rings and cylinders. Those parts are pretty much bedded in at the factory on the dyno.
It's all the other moving parts in the machine....camshaft journals lobes and tappets, fork slider bushings and transmission parts....etc etc
post #7 of 93 (permalink) Old 05-06-2019, 08:48 AM
lucydad's Avatar
All great advice above. I noticed on my Dragster RR that the suspension smoothed out also between brand new and about 1500 miles.
esq'z me likes this.
Never ride faster than your guardian angel can fly....
2018 MV Agusta 800 Brutale RR-- "Betttina" in Giallo-Nero
lucydad is offline
post #8 of 93 (permalink) Old 05-06-2019, 09:20 PM Thread Starter
SAROY's Avatar
Sorry if you feel this this is a constantly asked question, but as I have not received the bike as of yet and do not have the owners manual/hand book as of yet I thought I would ask the views of people who already own,
In the past I have purchased new F4's and ran them in; within reason of owners manual advice and had no issues, I am not new to bikes, but I do like to hear the expertise of others who own and share knowledge.
Things change over the years with engines etc so I was looking for pointers, obviously when it comes to brakes, tyres etc you always take same line of care with them.
Thankfully some have given some good advice of which I am grateful ---> appreciated guys, thank you
The bike will be getting delivered tomorrow and I will also chat with the bike shop and get their advice also.
I also know roughly what mapping set up and again this was simply due to asking guys who already have experience of this bike.
when it comes to tyres / oil, dont worry I know exactly what I need, so wont need to ask on here.
thanks again to all who assisted with good advice.
Kageira, nigelrb and DaveNZ like this.
SAROY is offline
post #9 of 93 (permalink) Old 05-06-2019, 11:23 PM
steved57's Avatar
Congrats on the new bike
SAROY likes this.
2008 MV Agusta F4 312R
2018 KTM 300XC
2010 KTM RC8
2003 Yamaha TZ 250
2019 KTM 350 SXF
2015 KTM 690 Enduro R
2017 KTM 1290 Super Duke GT
1974 Suzuki T500 Titan
1974 Honda CB 550-4
1970 Suzuki TS50 Maverick
2010 Harley Davidson XR 750 flat tracker
steved57 is offline
post #10 of 93 (permalink) Old 05-07-2019, 06:34 AM
@SAROY: What I feel is that there are questions that are asked frequently that are very subjective and have no true answer. I gave you my advice after a tongue in cheek response that should have set the tone for a lively discussion...and it did.
You got the expected answers of: "Just ride it", "Ride it in incrementally higher RPM", "Follow the Manual precisely" and I was surprised by the missing "Ride it like you stole it".
An engine is and engine is an engine. They, and the vehicles in which they reside, break in the same. All manuals essentially read the same: Don't be an idiot, learn your ____________, read your manual, and follow the break in rules. Common sense crap to keep a selling entity's liability lower.
The other side of that coin is that no one seems to use the ADVANCED SEARCH function to see what information....and there is a lot of it...that exists already.
Sorry if I ruffled your feathers with an actual answer instead of what you expected.
