Dragster 800 RR MY2018 - Neutral Revving - MVAgusta.net
 4Likes
post #1 of 27 (permalink) Old 03-30-2019, 02:54 AM Thread Starter
keishi34's Avatar
Question about my recently purchased Brutale Dragster 800 RR MY2018.
It seems my motorcycle does not rev over around 4000rpm?
Once I put the bike in 1st gear and rev it, it is the best sound I have ever heard.
Is there a way I could change the settings so that neutral will give me the same result?
Also, what is causing this?
I know it is not an issue with the bike, but I am relatively new to motorcycles and would like some assistance!
keishi34 is offline
post #2 of 27 (permalink) Old 03-30-2019, 05:51 AM
Black_Gold_Saw's Avatar
You said you're relatively new to riding a motorcycle.
How old are you, where do you live.
If it doesn't go over 4000 RPM it sounds like a electronic adjusted RPM limiter.
"Mileena"
Black_Gold_Saw is online now
post #3 of 27 (permalink) Old 03-30-2019, 06:05 AM Thread Starter
keishi34's Avatar
I’m in my early 20’s and ive ridden a YAMAHA MT-07 as my first bike for about 8 months, then switched to my Dragster 800 RR. I reside in Japan.
So if it is an RPM limiter, would I be able to remove the limiter?
LIVE TO RIDE,RIDE TO LIVE
YAMAHA★【MT-07 2017 Matte Black
MV AGUSTA★【Brutale Dragster 800 RR MY18 Nardo Grey
keishi34 is offline
post #4 of 27 (permalink) Old 03-30-2019, 06:14 AM
The idea i had in mind isn't it since you live in Japan.
To clarify: in neutral you can only rev to 4000rpm, but in 1/2/3/4/5/6 gear you can rev it to 13.000 rpm?
"Mileena"
post #5 of 27 (permalink) Old 03-30-2019, 06:52 AM Thread Starter
keishi34's Avatar
So does that mean Japan has a rev limit to all motorcycles? Or specific to mine?
I have not fully tried it out, but yes, at neutral only around 4000, and from gear 1~6, it goes much higher. Except, I have not fully tested this, so i am not quite sure if it red lines.
keishi34 is offline
post #6 of 27 (permalink) Old 03-30-2019, 07:01 AM
Well to actually know if you have a restricted version or not we need to know where the rpm limiter kicks in.
"It goes much higher" isnt detailed information. So when you take a ride and she is all warmed up see where it kicks in.
There is also a chance you have the PIT limiter activated in the menu.
You recieved a manual when you picked up your bike it should explain how to activate/deactivate it. So thats the first thing you can check yourself.
"Mileena"
post #7 of 27 (permalink) Old 03-30-2019, 07:03 AM
There's a Pit Limiter on a Dragster? When did that happen? (and why would it be applied in neutral...?)
post #8 of 27 (permalink) Old 03-30-2019, 07:59 AM
Maybe it has a PIT limiter. Maybe it doesn't.
Those are the first things that came to mind.
"Mileena"
post #9 of 27 (permalink) Old 03-30-2019, 08:11 AM
Advice like this just sends someone down a rabbit hole.
Mschwechter likes this.
post #10 of 27 (permalink) Old 03-30-2019, 08:13 AM
Go back to your delivering dealer and have them go over the bike with you.
Have them explain the behavior.
