2016 Dragster RR starting issue. Help required! - MVAgusta.net
Closed Thread
post #1 of 15 (permalink) Old 03-25-2019, 12:55 PM Thread Starter
Hello guys, i am new to this forum and i just recently joined the community. I am highly relieved to have found this forum as i was worried that i have no options left. This forum may just be my last saving grace and i will be greatly in debt if i can get any insight.
The thing is my bike which is 2016 model dragster rr suddenly has this weird issue of not staying on idle, it just shuts off. Bike starts just fine no problem starting but the bike only remains on for just a few seconds and the ignition just cuts off as if i have hit the killswitch.
I have contacted the dealer and the mechanic just checked all possible problems like battery, starter relay, ignition switch, sprag clutch and all electric wires and terminals but to no vain the problem still persist.
Guys any help will be greatly appreciated. Thanks
post #2 of 15 (permalink) Old 03-25-2019, 12:58 PM Thread Starter
Oh and i forgot to mention bike just clocked 2200 kms only. Weird how can such a problem occur on such a low mileage bike.
post #3 of 15 (permalink) Old 03-25-2019, 01:14 PM
Black_Gold_Saw's Avatar
Check if the fuelline isnt blocked when fitting the gastank.
"Mileena"
Black_Gold_Saw is online now
post #4 of 15 (permalink) Old 03-25-2019, 01:45 PM Thread Starter
Already checked the fuel line. I also cleaned the gas tank as well as fuel pump. Dumped the old gas and filled in new gas still same issue.
post #5 of 15 (permalink) Old 03-25-2019, 02:08 PM
hm... rereading your first post.
These bikes need to be started with the clutch pulled in.
So double check if you dont have to bike in gear, check if kickstand isnt down when releasing the clutchlever.
Check fusebox for good fit or broken fuse? I believe #1 or #3 is the one that has to do with the fireignition. (DONT QOUTE ME ON THIS!!! CHECK YOUR (Engine/workshop) MANUAL FIRST WHICH NUMBER IT IS THAT CONTROLS IT!!!!!!!)
PS: Im no expert in this. Im just suggesting things that have been mentioned before with similar issues.
Im sure people will come by and try to help you out.
"Mileena"
post #6 of 15 (permalink) Old 03-25-2019, 02:18 PM Thread Starter
Thanks for your suggestion will definitely check.
post #7 of 15 (permalink) Old 03-25-2019, 02:22 PM Thread Starter
I will post a video as quickly as i can. Hope one of you experts can send me through right direction.
post #8 of 15 (permalink) Old 03-26-2019, 04:52 AM
Bruce Taylor's Avatar
Another very useful website that you might try www.facebook.com/groups/mvagustaownersandriders/
Bruce Taylor is offline
post #9 of 15 (permalink) Old 03-26-2019, 06:28 AM
Please put your location in your profile and your bike year and model in your signature line through USER CP.
You really need to describe the condition more clearly.
Please describe the process from start to shut off in detail.
post #10 of 15 (permalink) Old 03-26-2019, 11:51 AM Thread Starter
Its a 2016 model dragster rr. When i first turn on the key and everything appears to be normal on the dash and when i press the ignition switch nothing happens like there is no crank or anything. Then i once again turn off the key and again turn on the key and press the ignition switch the bike starts but it shuts off after 3-5 seconds. I checked and replaced the ignition switch but the issue still prevails. Please help me guys!
Closed Thread
